- Joined
- Jun 5, 2007
- Messages
- 1,762
I’ve read through a bunch of Astro boost stuff and can’t seem to find the answer I’m looking for.
Pretty simple question. I’m thinking I need to cut the loop off the boost pushrod and thread it for 3/8s fine thread. Other option is to shim the unit in between the angle bracket and boost unit. Pushing the unit forward until the loop lines up. But that seems wrong.
So if I’m cutting it and threading it, is it there a common length everyone cuts the pushrod to? Or just guess till it fits? But really what to make sure of is that folks are cutting and threading the rod. The rod is basically 3/8s so I’m guessing it’s the correct size. As the little forks threads are 3/8s fine.
And I tried searching for a definitive answer, but couldn’t find a specific answer for a 90 through 93 Astro boost unit to angle bracket answer. And I’m not skilled enough to let myself make it up as I go along when brakes are involved.
