OK, so everybody knows I hate automatics...but @nvrstuk convinced me that they are the future, and I am a dinosaur. I think @lars and @Yeller were also auto proponents.
So to postpone extinction, I built my crawler and left my NV4500 in the shed. Can those of you that crawl with an automatic PLEASE tell me how to drive it?
I have a fuel injected engine putting out a nominal 75 lb-ft of torque at idle. Then I have:
Torque converter nominal stall, 1.8 ratio.
Transmission first gear, 2.80
Doubler, 2.72
Transfer case, 4.0
Rear axle, 5.38
Crawl ratio = 164.
Effective torque multiplication = 295.
Wheel torque at idle at stall = 22,125 lb-ft.
I can't stop this thing. In neutral, with brakes fully applied, I can lock up all 4 wheels. But in gear, my engine torque idles thru the brakes. Dropping from reverse to neutral to first results in some pretty significant suspension jacking.
I was playing in the rocks, and I came down over an obstacle onto my rocker. My spotter told me to stop, reverse a little, as he moved a rock into the hole. Reverse was easy, I climbed right backwards, but of course the brakes wouldn't hold. So roll forward, but again...it won't stop. So shift to neutral again. So I find myself cycling into neutral a lot. Going from Low to Reverse requires paying attention. Reverse to low...pretty easy. It was actually easier to wheel it with the transfer case in high.
So here's my technical question for you automatic guru's. Where is the right place in the valve body to install a valve to force neutral? I don't want to shift it. I just want to defeat it momentarily.
Doubler, 2.72
Transfer case, 4.0
Rear axle, 5.38
Crawl ratio = 164.
