AUX. Lighting
74BroncoCO
Kyle, I came across your website a while back when I was searching for LED's. You're LED is a great light and I have seen side by side comparison of them. Very impressive and while worth the cost, still a little more than I wanted to spend to put rock lites on my bronco. I will take a look around the rest of your site.
J.D.
4Roundeyes
Placerville, CA
J.D.
How many LED's were you looking to put on your Bronco?
74BroncoCO
The idea was to get enough lights to be able to rock crawl at night and not have to have the headlights on. Seems that would take at least 4 LEDs, one on each corner, but then it'd be nice to have a couple in the rockers as well to see what's under you too. So ideally it seems it would take 6 of what you sell to do a good job. What would you do? Do both styles of your LED's have a 6' radius? How is that afftected if they're only mounted a couple feet from the ground?
J.D.
4Roundeyes
Placerville, CA
J.D.
Great questions J.D. Let's start by saying that 6 seems to be the best number of LED's to get what you are after. One in the rear of each front tire and one in the front of each rear tire, then one on each end of the vehicle. Or others we have known put them up above each axle to see the drivelines.
Personally, I would mount some small fog lamps for forward lighting while night wheeling. Though these are a blue tinted lens, the light is actually white.
http://www.roundeyes.com/product_info.php?cPath=53_62&products_id=8391
Additionally, adding the 6 LED's will give you plenty of light to see around your vehicle and up under it.
For your last questions, both styles of our LED's utilize the same LED. Giving a dispersion pattern of 180 degrees from the LED itself will yield your 5 to 6' radius of light. Realistically though, the mini LED's are best used as interior lights and the Ultimate LED's for up under the rig. They seem to glow a bit more because of the plastic reflector around them. Better still, leave them on all night and your vehicle will start in the morning.
Hopefully this mumbo jumbo makes good sense and helps in your decision but we're pretty easy here. If you purchase something and don't like it, we'll refund your money. We want you to like what you buy.
74BroncoCO
Thanks for the info. I appreciate and understand what you are saying. And I know I speak for everyone when I say that Customer support is just as important as the product and it sounds like yours is top notch. I will keep you in mind for future modifications.
J.D.
4Roundeyes
Placerville, CA
J.D.
Thank your for your kind words. Let us know if you need anything.
MisFitToy
Calif
Now if you want to get serious about some bright offroad lights then check out the Narva Line of off road lights. I have some mounted under my Bronco as well as some I am going to be mounting on my front bumper. To give you and idea of how bright they are, I live in the middle of no where, not a single light to be found. I hit my lights and the entire road looks like daytime. I hit the underside lights and I don't even need my headlights on to see where I am going. I mounted one of their ‘Gamma’ Xenon lights, just to see how bright it was and not only was it cool looking because it comes in a aluminum housing but it made my 1/4 mile driveway look like it was day time. I don't think that the car passing my driveway appreciated it too much since I was shinning it that way at the time, but I sure loved it. I know of two people here in the states selling Narva lights one is http://www.safarilighting.com/ I can't remember the other. I will look for them and when I find it I will post the link.
MisFitToy
4Roundeyes
Placerville, CA
MisFitToy
Hi MisFitToy,
Those light are nice. :) Really bright! I would love to see some pics of your rig with the Narva lights on them.
Skuzzlebutt
PhD, Dr. of Broncology
Honeymoon Bay
Going back to the original question, the easiest thing to do is to buy higher wattage bulbs to fit the Hellas you already have :cool:
