I counted twice and got 30 both times but I kept seeing references to 31 splines and thought I miscounted.
As you may have figured out, the constant mentions of 31-spline setups is strictly for the Ford rear end.
The front is a Dana and correct at 30.
This one has an automatic, and I’ll upgrade to an automatic with OD. I haven’t done the research yet to determine which one will work best.
The current go-to is the Ford 4R70w auto from later Explorers. But there are others if you're casting a wide look.
I don’t plan on wheeling it much if at all, maybe some logging roads getting to hunters to track once in a while but currently using my tundra for that. May take it on the beach occasionally.
Not a lot in there to recommend spending the extra money on a limited-slip differential then. However, the beach alone might justify the cost.
It's one of those decisions in the long list of many (like gear ratio in fact) that could go either way. You have to decide if it's worth it, and do it while the work is going on.
What I’m really looking for is better drivability, not huge horsepower.
Good. Broncos really benefit from low-speed characteristics of the engine. Built for throttle response, smooth idle, economy (within reason) and reasonably high torque numbers without going bonkers is a key to a happy owner. Unless you happen to thrive on burnouts and full-throttle high speed runs that is!
Neither of my EBs have tachs yet, but they sound like I’m winding them out at 45 mph.
Well, maybe they are. But most likely they're not and you're just used to how other vehicles sound. I was used to Broncos and I still thought mine sounded tapped out earlier than all the others I'd driven. It was 100% the exhaust in my case. How is yours set up?
And what size tires? You need to check your gearing now, because if you already have 4.11's or even something lower swapped in after it left the factory, you might as well know now.
You said you have this one apart, so just count the teeth on both gears and let us know what ratio you have. A 4.11 would mean it sucks to be you...;D
What I mean by that is that it would have been nice to be able to drive it with the new engine and transmission FIRST, before pulling it apart. That way you would know how it felt with the existing gearing.
Avoiding Broncobowsher's 3rd theory of Bronco-relativity.
Because it's apart you can't do this with the Bronco now, but what about the other one? Still driving it? Then put a tach on it temporarily just to see what it's doing in reality and compare that to the sound you're hearing. These things make a ton of noise from gear whine, big metal fans spinning under the hood, old bearings maybe, noisy tires, and just about anything else that can ring it's way through a tin can and into your head.
And for gear ratios, I’m running 33s and will eventually put in an overdrive tranny. I’m thinking 4:11 or 4:30?
456 if I decide to go to 35s?
Narrow 33's, or 12.50's?
Motor wise, current plan is Blueprint 306 bronco crate motor with fuel injection but that may be a while.
Got a link to the exact one you're contemplating? Just curious what it's power ratings and curves are. This is good stuff for you to study too, to help in the ultimate gear selection.
As mentioned, mine is at one extreme with 4.56 and 31's. This gearing is actually pretty sweet for off-road, but while not optimum for highway, is very usable still with the Explorer engine. With the overdrive 4R70w trans, I'm still spinning the engine much less than my 4.11 and 32" combination.
I know without doubt this thing would be sweet-on-the-street with the dreaded 3.50's and the 31's and I'm going to test that someday. Even though that would put my cruising rpm way below what is normally recommended for a Bronco and carbureted stock-ish engine.
Which is the point I'm finally trying to reiterate. What's good for one engine may be intolerably dull for another.
Which is why the "good luck" has a lot of meaning here.;D
