Axle selection
BruiserOutdoors
BruiserOutdoors
How close to stock WMS are you hoping for?
I think there are a couple choices out there that make them easier to narrow.
Probably the closer to stock the better, i would prefer the tire not to stick out all too much. Also, would like to consider staying 5 lug.
What narrowed options are possible with axle shafts readily available?
ntsqd
heratic car camper
Upper SoKA
If you wanted 37's and are compromising to 35's, how long before the 37 bug swings back around and bites you? And then when we actually get snow again and you discover just how deep it can get and decide that you need 40's? :)
A lot of talk about the front axle, but the rear needs to be addressed too. I think that your intended use is past the point of a 9" in any form. Same story as with the front, sure you can build a 9" to mostly handle it; and deal with the breakages as they happen.
OR for less overall cost you can go right to a 14bff and once set up not likely have to do much more than maintain it.
A key thing, do you have wheels that you like and want to keep, or will you need to buy some? If the latter then just go 8 lug from the start. It'll cut a lot of BS and cost out of the project. Making a front D60 and a rear 14bff have the 5x5.5 bolt pattern can be done, but it gets spendy pretty quick. OTOH both come already 8 lug at no cost.
BruiserOutdoors
BruiserOutdoors
I am already planning for 37s with zero anticipation of going bigger. Just build it once is my goal/hope. 37s will be more than plenty for me. I could see myself wanting to go 35s before going bigger.
I already have 5 lug wheels i'd like to run, but the cost to keep them could outweigh the practicality of keeping them.
Jumping to 8 lug will want to make me run beadlocks, which continues to snowball the budget...
ntsqd
heratic car camper
Upper SoKA
I tried really hard to keep the 5x5.5 bolt pattern, but it just wasn't reasonable in cost. I didn't want bead-locks, but I could not get the 8 lug wheel that I wanted in the back-space that I needed w/o them.
I wanted a rear D60 to keep the unsprung weight down. That really makes things complicated, and the crawler types on another shall-remain-un-named forum think it a ridiculous idea. I never found a 5x5.5 wheel hub for a rear D60, only for fronts. They are made for 14bff though. Same mfg makes 5x5.5 front D60 wheel hubs, so it can be done with that axle combo.
https://solidaxle.com/collections/wheel-hubs
Yeller
Rogers County Oklahoma
^^^^ 100% solid info there. Just went through the same digging/research match to see if maybe someone came up with something recently, no dice. I've built a lot of axles and have never been able to make the jump to 5x5.5 or 6x5.5 for anywhere near the cost of a really nice set of bead locks.
Me building a front for your application I'd find a 1980-1998 ford front king pin or ball joint, and a 14 bolt. Shorten the front long side 6”, pick your locker, gear, 35 spine axles and stock brakes. The rear look for a cab/chassis axle, they are 63” wide, do the cheap disc brake swap, pick your gear and locker, done and ready.
nvrstuk
PNW
I addressed stepping up to a 14 bolt earlier. Don't waste a ton of $$ trying to keep the 9".I can tell you why it wont last. ...makes it easier to switch to 8 lug wheels also.
Here's the key for your 6r swap. You HAVE to shorten the DS to move the HP D60 over to the DS for driveshaft clearance issues since you aren't going FW.
Be careful whacking a predetermined amount from the pass side w/o consideration of the 6r clearing the back corner of the 6r and the shifter linkage because of your trans.
I think you'd be upset if you had some shop narrow the axle to your desired wms and then you didnt have driveshaft clearance...that would be a bad day!
6r is making the difference here.
hossbronco
I think a 9” will last, but it will take a ton of money to get it there. Think Gearworks third member and a competition ARB in a 609 axle. This is definitely not a cheap option, though there are some big benefits.
If you're wheeling like nvrstuk, use nvrstuk axle recommendations. He's been proving it out for years and has blown up his 9” more than once. The Dana 60 front seems like a winner for your application. The 14 bolt would be a very strong rear axle and give you peace of mind. With only running 37s you'd definitely want to shave it.
Yeller
Or just let drag, been shaving on mine for 20 years. It's almost a 13 bolt now:p
By now had I shaved it I would have had to rebuild the bottom of the housing due to it not holding oil anymore at least once, maybe twice.
ntsqd
heratic car camper
Upper SoKA
I didn't shave this rear D60 that I'm working on, but I did take a sanding disc to it and smooth over all of the steps, edges, and bumps on the bottom of it. No point in leaving those to hang up on the rocks and slowly be ground down. I did briefly debate forming some Core-10 to fit the bottom and welding it into place to make the bottom smooth and free of any abrupt changes in shape. I decided that for this truck's use that was excessive overkill. Were it a crawler I'd likely do it.
nvrstuk
PNW
I talked with GearWorks twice about running their 10" HP 5.38 gears in my 9" aftermarket housing. It would fit, that wasn't the issue. Number of miles I put on was the issue.
They inspect and regear a huge percentage of the units they assemble (in chase trucks) after 15K miles. Granted, they are under load a higher percentage of the time that mine is but, even replacing the gear set every 25K miles for a price of $4-5K each time to me is a definite no-go. Can't afford that for sure!
It sure would have been easier.
hossbronco
I can't imagine you would need to change out the gears every 25K miles. The TTs that do that are sponsored and probably being extra cautious. Their gears are U.S. made by U.S. Gear and are shot peened and REM polished. I would expect them to last longer than OEM gears, even though they probably won't guarantee anything.
With the hypoid distance the 9 inch has more gear engagement than the Dana 60, but running on the coast side does reduce the strength of a high pinion in the rear axle. A low pinion 9 inch with upgraded components is plenty strong and is run in many TTs. The 14 bolt is significantly cheaper and probably stronger. You could also get a built Dana 80 for cheaper than a built 609 rear. In addition, the Gearworks 9 inch is 5.43, and pushes the limit of what you would want to run on the street when your Dana 60 is 5.38. If I ran that combo, a 5.13 front and 5.14 rear would be much better.
Now if you take cost out of the equation, I'd take a 609 front over a Dana 60 any day.
Madgyver
Bronco Madman
nvrstuk has a 60 and a 14 I believe.
I'll be doing a 60 and a 10.25 soon because I acquired a set locally for a great price. They are sitting on some axle dollys waiting.
nvrstuk
PNW
Well, I spent a lot of time talking to one of the top guys at GearWorks about their 10" gear sets.
I knew very little about them and had to rely on what I was told from whom I understood (and was told) was one of the top guys (I don't remember his name as I tossed all my notes since his company recommended I not run their gears- and you're right, they were 5.43's).
Since I had destroyed 2 rear TruHi 9 rear ends I was a bit gunshy going with a 609 up frt since I had been recommended to not run on the backside of any gears since they were not lasting for me in the rear-different but I'd burned a lot of coin already. I'm not sponsored so replacing "top tier" parts when they should last much longer was getting old to say the least. Even with the 10" gear set I'd still have my 35 spline ARB which I'd already twisted in half so I'd have to go with their competition 35 spline unit which was double the stock price! Where's it end right?? :(
I had a HP 60 already set up with ARB and 5.13's for the rear that I was thinking of running in the rear but was convinced by several racing teams that it wouldn't last at all- especially since I described previous failures and my drivetrain/engine combinations.
So I shaved a 14bolt and built a HP 60 with RCV's for the frt. Its holding up fine for thousands and thousands (& thousands) less than a 609frt and Gearworks 10 rear or other combinations.
hossbronco
Thanks for your comments, Brian. Your experience is definitely appreciated. This conversation matters to me because I'm planning on running 609s and HP10s front and rear. I'm probably more of a finesse driver than you are, but I want the option to drive like you.
I'm surprised you were told not to run their Gearworks' stuff, but I agree that you'd be happier with a 14 bolt. I'd be curious if you can ever remember who told you that. The benefit of the 609 for me is that I really want to run 5.38 or 5.43 gears, but not both. I feel the HP10s are a much better design than the True Hi9, though I'm not sure about the Mega Hi9. In addition to clearance, weight, and the convenience of a third member, running the 609 rear gives me a better gear combination to run a 609 up front. With a 609 I can run 40 spline shafts and 1480 U-joints at the diff. Dynatrac doesn't recommend going 40 spline with their Dana 60s because the gears become the weak link. If I were to go away from the 609s, I'd probably run a Dana 60/80 combo.
Do you mind clarifying a couple of things? You mentioned not wanting to run on the backside of gears up front. With an HP10 you would be running on the backside of the gears in the rear, but not the front, correct? They should be plenty strong up front; stronger than a Dana 60. Also, what year was you ARB from? There were design flaws that were corrected with the competition version a few years back, though I'm told that those flaws in the street version have now been addressed as well. There is some concern with the size of a 9 inch differential limiting the size of the ARB. If you run 40 spline, you only have the competition version available.
Also, I'm sure you know this, but for everyone's benefit, the 10 inch ring gear for 9 inch differentials really measures at 9.5 inches.
Yeller
In all of the Hi9's I've been involved with the only one we ever broke involved a crash with another vehicle at 70mph. It was violent enough to twist a 300m 35 spline RCV stub shaft 180 degrees. It cracked the ring gear, still finished the last 50 miles of the race (KOH). I'm still not comfortable with an ARB in a 9" even though they are supposed to be fixed, they were supposed to be fixed the last few revisions as well.
hossbronco
There's a thread on Pirate somewhere about people having issues with their Hi9s and switching to HP10s and being happy. I think driving style and terrain have a lot to do with it. Have you been involved with many in the rear or have they all been in the front?
I know Gordon Bailie has had a lot of success with a Hi9 rear, but he spends a lot of time in the rocks. Brian blew up his Hi9 rear, I'm guessing in the sand, though it may be the ARB that actually failed him. There's a thread on Pirate for that too. Hi9s are great because you can run them in your stock housing. HP10s require new housings.
Yeller
I have lots of experience front and rear. in a rear they are more fragile, but do stand up well to slow, non-shock load, high torque use like Gordon does. The only front I've personally worked on that was damaged was in the story above, missed that I guess.
Y'all need to quit screwing around with those puny axles and move to axles rated for the use.
https://www.meritor.com/products/axles/single-rear-drive/pro-tec-5000-series
There IS a buggy in NV built using a pair of these axles with a build thread on POR. It even has a Ford engine in it!
I have Rockwells in my buggy, been thrashed for a couple of decades now without failure;D
That's the first time I've seen a 24.81 axle gear ratio. :eek:
I have one in a Case backhoe LOL
nvrstuk
PNW
Hoss- I wrack up a lot of miles. GW's main concern was about that. He (once again can't remember name) and I'm not home the next two weeks to even look for any notes- but other than bumping up to 5.43's and being told they (GW) were working at designing/building a higher ratio like 5.13's but possibly a few years down the road- but for what I needed at the time I roughly remember it was going to cost appr $5K per axle AND it wasnt the ratio I had calculated for my mix of street driving & wheeling. I didn't want to cruise at 70-75 at 2400rpm with my long stroked stroker. ;)
I might have made it confusing in my earlier post about being gunshy about running on the backside of the gears and then started rambling ;) about a 609 frt which of course wouldnt be running on the backside-however, I was mentally and financially DONE with TruHi9's. Their Mega 5.38's looked like a different animal but "once burned, twice shy" - there wasn't going to be a third time! lol
Once again tho the only option for a 35 spline ARB that wouldn't literally twist in half as this wasnt the engagement sprocket problem failure problem ARB attempted to correct, this was literally twisting the case into 2 pieces with a 6K shift on asphalt - I think I learned my lesson there. :) I saved the pcs.
ARB phone jockeys said they'd never heard of it before but I talked with 4 other ex ARB employees who work for MULE and Tim who everyone knew back in the late '80's and '90's as the ARB guy -they all knew of a couple that twisted like this. So in my mind it could happen again.
So for me, it was:
-why go with rear gears not recommended to me by one of the top guys of that company
- still stuck using an ARB that had twisted literally in half and to fix that buy the competition unit for appr $4K that used air to unlock abecause the competition unit defaults.to locked axles w/o air.
- and I would have to spend appr $5‐6K for the frt to ALMOST match the rear gearset #'s and for me having to drive on ice/snow covered roads 20 miles each way to go snow wheeling this I felt was not the best matchup for keeping my short, narrow, tall Bronco going straight down a ice covered County road to go wheeling. :(
‐ then I'd still be out another $1500 for a different ARB up frt.
Agonizing but an easy choice for the pocket.
But like you said low shock, high torque use is ok like what Gordon does but TruHi9's dont like 6K shifts into 2nd on asphalt with 40"s... guess thats "high torque" lol
