Axle selection
Yeller
Rogers County Oklahoma
I've had good luck with the sealing of the caps as long as they are built like RCV's that cover bolts to a plate and the puck free floats in the splines. you can get enough ritestuff on everything to make it seal and the cap is not being affected by the torque on the puck.
jamesroney
Fremont, CA
I'd forgotten about the spin-welding, but yeah the one that I cut up had it's spindles welded on with that process too.
I wish that I had thought to save those spindles.....
@ jamesroney, how well do the caps over your drive-slug system seal? Seemed like MISF battle that the whole time he had that Warn FF system in place. They were always weeping at least a little.
Well, now that's an interesting question. This particular set of caps uses an o-ring seal on the OD, and 4 small o-rings on the 1/4-20 SHCS. But they didn't counterbore the seats and so you only get 1 install before you wipe the o-ring.
But it turns out that there are two options for securing the cap to the hub. there is a threaded retainer that allows you to attach the cap to the hub, OR, you can rotate the cap 45 degrees, and sandwich the retainer plate and bolt directly to the drive slug. I'm not sure what the manufacturer had in mind...but if you sandwich the plate, then the bolts work themselves loose, and somehow break off. When the screw breaks off, the o-ring doesn't matter anymore. But the leak is instant.
I'm working on another D60 Full Float this weekend with the actual Warn big hub kit in it. It's running the Warn 35 spline unlock hub with the added set screw. I was never been able to keep those from leaking, until I added a seal to the inner shaft, and packed the bearings with grease. It's in a Willys M38 that gets flat towed a lot. And it's held up...but I hate those Warn lockouts. They don't seal so well with gear oil.
I'm running the mile marker big hub lockouts on my spinTec floater kit in my Cummins. I've got over 100K on them, but they also leak, and a couple of the retaining screws are bouncing on the highway somewhere. Its a curse, but hey...I don't have any unit bearings, and I'm good for a million miles.
Madgyver
Bronco Madman
Thanks Steve for pointing me towards the 14 bolt. Like the heavy as pig myths about frt D60's, the 14 bolts have the arse hanging low reputation. The bottom of my shaved 14 bolt is within an 1/8" of the bottom of my aftermarket 9" housing and weighs (I think w/o looking on my build sheet) within 15#'s. Should have done this upgrade 25 yrs ago and saved enough money to buy a beach house in Hawaii. :)
beach houses here are expensive... we just camp out on the rocks....
ntsqd
heratic car camper
Upper SoKA
The very nature of a drive slug makes me think bolting anything to it is a bad plan. It is supposed to float some and trying to hold it fixed is asking for it to fail something. I would bet that the threaded holes in it are more about being able to grab it for extraction and someone didn't think to put those threaded holes on a different bolt circle so that there would be no confusion as to intent.
Too bad there isn't an Aisin locking hub to fit. I've come to view them as far superior to anything domestic. I do like the Superwinch hubs of the Blanc-Oh!, but they do weep too. Not to mention that Westin kilt them off when they bought Superwinch. Boo Westin!
My fall-back to leaking anything has long been Hylomar, but I hate to use it if there's a better way that actually works. As opposed to, say, the side plate o-ring glands on a Hewland Mk II-VII transaxle which I think are the reason that the English invented Hylomar in the first place.
Dang you Brian! That RCV page incites me to spend money of cool stuff that I don't really need.
nvrstuk
PNW
Ain't that right TS!! :) This FF setup worked great for me. Actually got to use them as intended when I had another unfortunate TruHi9 failure at the top of a large sand dune in horrific winds! Nasty sand storm!!! Tried to shield ourselves with tarps. I pulled one FF cap, slid the axle out and got out of there in FWD. Drove for the next 11months in FWD as I had major shoulder surgery and couldn't lift a wrench much less my arm for 8 months.
ntsqd
heratic car camper
Upper SoKA
yeah but......
I've been pondering another glass buggy build and that doesn't help. One with Aisin locking hubs on the rear to make flat towing simple so that I can justify calling it the camper's dinghy. That means custom outer stubs, 930 CVJ's (cue RCV), and some SAW drive-axles. And about 3k worth of 091 or 094 transaxle. And about...........
argh!
hossbronco
Hoss- I wrack up a lot of miles. GW's main concern was about that. He (once again can't remember name) and I'm not home the next two weeks to even look for any notes- but other than bumping up to 5.43's and being told they (GW) were working at designing/building a higher ratio like 5.13's but possibly a few years down the road- but for what I needed at the time I roughly remember it was going to cost appr $5K per axle AND it wasnt the ratio I had calculated for my mix of street driving & wheeling. I didn't want to cruise at 70-75 at 2400rpm with my long stroked stroker. ;)
I might have made it confusing in my earlier post about being gunshy about running on the backside of the gears and then started rambling ;) about a 609 frt which of course wouldnt be running on the backside-however, I was mentally and financially DONE with TruHi9's. Their Mega 5.38's looked like a different animal but "once burned, twice shy" - there wasn't going to be a third time! lol
Once again tho the only option for a 35 spline ARB that wouldn't literally twist in half as this wasnt the engagement sprocket problem failure problem ARB attempted to correct, this was literally twisting the case into 2 pieces with a 6K shift on asphalt - I think I learned my lesson there. :) I saved the pcs.
ARB phone jockeys said they'd never heard of it before but I talked with 4 other ex ARB employees who work for MULE and Tim who everyone knew back in the late '80's and '90's as the ARB guy -they all knew of a couple that twisted like this. So in my mind it could happen again.
So for me, it was:
-why go with rear gears not recommended to me by one of the top guys of that company
- still stuck using an ARB that had twisted literally in half and to fix that buy the competition unit for appr $4K that used air to unlock abecause the competition unit defaults.to locked axles w/o air.
- and I would have to spend appr $5‐6K for the frt to ALMOST match the rear gearset #'s and for me having to drive on ice/snow covered roads 20 miles each way to go snow wheeling this I felt was not the best matchup for keeping my short, narrow, tall Bronco going straight down a ice covered County road to go wheeling. :(
‐ then I'd still be out another $1500 for a different ARB up frt.
Agonizing but an easy choice for the pocket.
But like you said low shock, high torque use is ok like what Gordon does but TruHi9's dont like 6K shifts into 2nd on asphalt with 40"s... guess thats "high torque" lol
nvrstuk, I called ARB, and they said that all of their lockers, even their competition lockers, are energize to lock. I called GearWorks and they agreed that the RD249CE, which is their 40 spline competition ARB for a Ford 10”, is energize to lock. That’s good because energize to unlock would have been a deal breaker for me.
ntsqd
heratic car camper
Upper SoKA
I'm not aware of any selectable lockers that are energize to unlock. Are there any? Even my D60's OX with air actuation is energize to lock.
hossbronco
For what it’s worth, the guy at GearWorks said he keeps hearing that rumor from customers.
hossbronco
Are you suggesting it’s correct, or are you saying they went another direction?
Rustytruck
well my thoughts is build a good rear axle. if it fails your stuck with no way to get home. upgrade the crush sleeve to solid spacer run as much spline as you can afford. with the torque you have you have to deal with axle wrap. then do the 300m output shaft on the dana 20. then when you get to the front then get a hard cover for the diff cover drilled and tapped for tension bolts to the main differential bearing caps. I dont like the thought of solid u-joint caps so would do rcv axles as a compromise. and yes you can easily bust this stuff up with the power you have. with the bigger tires you go the further back you can go until your really between a rock and a hard place. I am a light wheeler as I have had my 28 spline and detroit for over 35 years on 33" tires and yes I really worry about it but with the automatic and piss poor 1974 stock engine it has survived. and now I am slowing down in my later years.
nvrstuk
PNW
Took me a while but I found it! :) Like Steve said tho, I originally heard it was ARB but I did find that Yukon is making one.
Yukon has a competition model that defaults to lock without air supply.
The Yukon Zip Locker is the latest in on-demand traction. Its air-operated design allows you to switch from an open differential to 100% lockup when you need it, giving you the ultimate in driver selectability. This is a competition only unit that defaults to lock if air pressure is interrupted.
Not all models etc but it is what it is...
  • 4.56 and up ratio only
  • Forged case and 8620 internals for added strength
  • Works with a variety of air delivery systems
  • Assembled in the USA
  • Competition unit that defaults to lock if air pressure is interrupted
  • 6-year warranty against Manufacturer defects
hossbronco
Interesting. It’s probably great for competition, but it limits itself for other applications. I’m glad ARB didn’t do the same thing.
nvrstuk
PNW
They did list it as a competition unit tho. If I competed I think I'd want to fail "locked" rather than unlocked. Course marketing your "locking diff" as a sales point saying that WHEN it fails ... :)
hossbronco
Seems like a safety issue if you’re running around a bend on the highway and your locker fails and locks up on you. Maybe they don’t want the liability. There are situations offroad where you wouldn’t want it to just lock up on you either.
Yeller
having competed professionally crawling, fewer than you would think. Most of the times I can think of is an inconvenience more than an issue, unless your in snow/ice, then maybe in some conditions.
