Axle Widths?
broncoitis
Does anyone have a general idea of what the different axles measure. From say a 70's F150/250 vs a Bronco Axle? Got a project I am working on and curious as to the differences in width. Thanks!
Just a general idea of WMS to WMS for the axles would be cool doesn't have to be dead on accurate just pretty close.
Opps, this should be in Tech. My bad meant to put it there!
walls
58" stock EB
65" F150's (generally)
69" F250/350's (generally)
These are approximates. Hope this helps.
Yes, between 8- 10 inches depending on which rears. I took 8 off my 2000 f 250 rears which will make them 2 inches wider than my factory bronco housing measurements
broncoitis
broncoitis
58" stock EB
Thanks you guys! That does actually help alot. This isn't necessarily bronco related but info that I needed to make a decision. Probably look for some older F150 Axles! Don't think I need the bigger width of the F250/350 axles!
Gracias!
