B&M conversion light switch location
blknblu69v
I am reassembling a 69 Bronco with a Centech wiring kit. I have a B&M shifter that was installed from a previous owner. Where do I find the reverse light switch? Since it is no longer located on the column, I can't seem to locate where it was before the tear down. Thanks for your help!!
Viperwolf1
electron whisperer
It was at the engine end of the steering column when stock. Look for the black-red wires. Most floor shifters have optional switches that can be added to them.
B
blknblu69v
Thanks! I'll check that out. If I don't find the black-red wires, do you know who might carry the optional switches for the B&M shifter?
graniteguy
Kempner, TX
I would think any performance speed shop (summit, jegs, etc). Its usually a micro momentary switch like would be used for nitrous. B&M should have it with the correct bracket. Basically when you put the shifter into reverse either the shaft or something in the guts will push on the switch.
