66 brake light switch front disc conversion
Soell66
So has anyone did the front disc conversion on the 66? wondering what to do with the brake light switch. Tom's mentioned either going with the newer brake pedal set up with the switch on the pedal or doing a T in the line for the 66 brake light switch coming off the new dual reservoir MC. do they make a T for the line to do that to keep the original set up. The only thing on the new pedal is I have to buy the whole clutch and brake pedal assembly. Haven't found where you can just replace the brake pedal.
thegreatjustino
Red Head Grease Monkey
Stockton, CA
The pedal mounted switch mounts on the same peg as the push rod for the master cylinder.
Is there some difference between the peg on the pedal arm in '66 that would prevent mounting the switch there like it is on every other year EB?
I've never heard of the '66 brake pedal arm being unique to a '66. Not saying it isn't but of all the '66 differences I've learned about over the years, this isn't one I've ever heard of.
mrdrnac
I have a Wilwood master cylinder that is threaded for the hydraulic switch, which it comes with. However, you would be better off doing one on the brake pedal, I made a custom bracket for mine and used the push button style brake light switch. This allows you to adjust how quickly the brake lights come on, the hydraulic switch requires quite a bit of brake pedal pressure to come on. Not good in this day of tailgaters and roadrage!
BroncoNE
I got a quote from Tom's on my 66 and they said i would need a new brake pedal, switch, wiring pigtail, and brake push rod washer...
B RON CO
Statesville, NC
Hi, you can put the original Ford hydraulic brake light switch in line with the new setup very easily. From a line out of the master cylinder.
If you are upgrading a 66 with a single jug master cylinder, you need to get a dual bowl master cylinder, and a disc / drum proportioning valve. To make it all work better. Good luck
S
Soell66
Thanks everyone I bought the conversion kit from toms and a new master cylinder. They only thing they discussed once I ordered they called me to make sure I was aware the the brake light switch would have to be modified or the pedal.
Bukbugy
My 66 Does not have the holes in the frame for the proportional valve mount on my disc brake conversion. Is this normal for the 66, no problem to drill and tap. Also what does the pigtail wire off the valve get wired to?
66BlueGoose
Correct your 66, will not have holes for the proportion valve mount as it was not provided that year. Not certain your pigtails, assuming they are for the brake sensor?
