Bad Radius Arms?
tabyers
Indiana
Does this mean I have to get new arms or am I missing something?
langester
MASTER OF MADNESS
I have had to put a couple sets in a press to get them to match up. Not sure if that is the issue on yours or not but worth a shot.
tabyers
tabyers
Indiana
I don’t see anywhere that the arm portion is bent. I don’t have a press, maybe I’ll pop into a machine shop and get turned down by a couple of them. I’m wondering how many used arms I would have to buy in order to get a match.
sykanr0ng
Looking at how rusted away the back ends (top of the pic) are I would say to replace them anyway.
Those look like good candidates for making Lars bars out of.
langester
MASTER OF MADNESS
I was looking at the mismatch in the arms, I was assuming that was what you were talking about. My bad, I see the rust on the ends. I will say I have used some in the past that looked a little worse than those. To each their own on that issue for sure. I would agree that they would be great to make some Lars bars.
tabyers
tabyers
Indiana
Yeah, I was talking about the mismatch. I’m not too worried about the rust. Thanks to both of you for the input though. Aftermarket is expensive
Jfryjfry
If you rotated one of them 180 would they line up? If so, maybe you could just remount the shock mount and use them
there would still be re-drilling and tapping the spring cup mounting holes, so it's not a simple and quick operation. Not technically impossible I don't think. Just more work.
Never noticed a set like that where an arm was not bent somewhat. Often on purpose to fix the caster on one side, or fix a lean. But yeah, they sure both look straight.
But I don't think I'd be checking that on a pebbled surface like that either though. I'd find a smooth bit of concrete or steel, or even a thick board with a smooth surface and do the checking that way.
It would not take much of an imperfection in the surface at the face to offset something three feet up the line.
tabyers
tabyers
Indiana
I know, they seem awfully undamaged to be out like this. The broken up side walk is just were I took the picture. They do the same thing everywhere I take them.
jckkys
The photo may be saying more about the sidewalk surface than the arms.
tabyers
tabyers
Indiana
Seriously though, they look like this in the garage, on the porch, and in the living room too
tabyers
tabyers
Indiana
Good excuse to order some of duffs arms
so down the rabbit's hole I go, or more like money pit. Are there any added benefits from the Duff T-Rex stock length arms, other than my wife not grinding my 31x10.50's when turning left. I've got a 2.5" SL and currently run 7 degree bushings with my stock arms. Thanks again everybody!
Monster Mike
At first I thought these arms were just going to have a few cool benefits like you pointed out. As the testing continued the results were astounding.
I recently did a T. rex install video with Jon Melton from Nashville Early Broncos. The video will be out soon.
If you have any questions I am happy to help.
More great info here as well as the option to purchase:
https://www.dufftuff.com/Early_Bronco_T_Rex_Radius_Arms_p/5355.htm
MM
661buster1963
what did the classic sidewalk guys.com say
Mine were much like yours only bent 180 degrees the other way, very subtlety. I gently bumped them staring with a press. They bend a little easier in the other plane, but they really don't look like they were hit, maybe always were that way?>
tabyers
tabyers
Indiana
Yeah I'm thinking they might have been that way from the start. They came off a 77 donor with 40,000 miles on it.
I just went to a local Bronco builder today and picked up a matched pair. Looked at probably 8 different sets and they all had something wrong. These things must live a hard life.
The classic sidewalk guys said $2,300 for something totally un-Bronco related. I said No Thank you!
You are not measuring a valid reference point. The critical surface is where they interface with the bushing. That machined flat that you are resting them on means nothing. Mount them on the axle and are the frame ends of the arms at the same plane? Remember the bronco lean fix of playing with tightening sequence and try again. I'm pretty sure that they will work just fine. Might take a few tries to get the bushings in and the arms level to each other, but I get they will do it.
tabyers
tabyers
Indiana
Yes I think you’re right. It’s been so long since I installed new c bushings that I forgot the details, but I must have been able to compensate for the difference somewhat. The truck did lean a little but when put on the floor with the tires still on, they weren’t that off from hitting at the same time. So that is a great point. I’m down to nuts and bolts and boxes right now, getting ready for body replacement so I’m trying to make good decisions so I’ve got the best chance to end up with a restore that is as clean as I can get it done. (Given my budget and application.) So... I found some ones in better condition. Might go Duff T-Rex in the future but I have a lot of my bronco budget tied up for a minute.
