Battery cables
MikeCon
Looking for 2 gauge cables for 73 with 302.
30" starter cable,24" ground,12 " solenoid.
Quality.
chuckji
SE Michigan
Get yourself some welding cable (it’s much more flexible than typical battery cable), ring terminals and solder slugs - then have at it.
rpmgarage22
If you are interested in having me build a set for you, you can PM me.
I have 4ga and 2ga and you can specify the size/shape of terminals. I use copper terminals, and solder/hammer crimp all the connections, then finish with heavy gauge color matched shrink tube over the joints.
I also build complete power distribution centers to supplement your current wiring capabilities. Here is a link to some of them:
https://classicbroncos.com/forums/showthread.php?t=299764
Do you have high amperage needs due to accessories, winch, stereo, etc.?
Gave up buying off the shelf. All made to a price point. Bought a tool and crimp my own.
KyleQ
Welding cable, red and black colored shrink tubing and an anvil style mechanical crimper.
jhill52
My local auto parts store made mine using welding cable and they had a crimping tool. Turned out nice,
chuckyb
Jeffs Bronco Graveyard has a nice set. Can add the Starter cable too.
I got the HD cable set from Jeff’s. It’s a nice set for sure but I found the positive cable to be too short. I had to move the starter solenoid from the stock location on the side of the wheel well up to the front of the wheel well to make it fit.
MikeCon
MikeCon
Replaced old 4 guage with 2 guage. Starts immediately warmed up or cold.
Thanks for the input..
Time to chase the front end clunck.. Gonna try u joints. Everything else looks OK.
Sounds like they based their sizing on the later ('69 and later?) location.
And probably a good thing too ultimately. As long as they could still last, getting the relay farther away from the exhaust heat is not a bad thing.
