Battery Draw
74bronc
I know this has been covered, but I need some quick ideas. My battery was low again today after the bronco has sat for about a week over Christmas holiday. The battery was fully charged and load tested a few weekends ago. Anyway, I have a draw on the battery and I need some ideas where to start.
What i have already done (checking with a test light connected between the negative batt terminal and neg batt cable):
pulled each fuse
disconnected alt regulator
disconnected cig lighter
still need to disconnect ign switch and headlamp switch.
where else could i have a draw from?
CDOG
Tucson
I replaced the alternator and voltage regulator and that fixed my draw problem. I had, in a rush, touched the terminals to the wrong posts so I caused my problem myself
74bronc
74bronc
nevermind! I just found the problem.
I will explain just in case this helps someone in the future. It turned out to be the horn relay, near the starter solenoid, that was causing the draw. Basically I started thinking of the circuits that are "switched HOT" and then eliminated those and concentrated on the ones that have constant HOT at them all the time (horn, brake lights, cig lighter, headlight switch, ign switch). There is a yellow wire on the positive battery cable side of the starter solenoid and when I disconnected that, the draw went away. Traced it to the horn relay. I had never even thought about the horn relay before, so maybe this will help someone else out in a similar predicament.
