Battery draw
beaux312
Hartford, AL
I think I have a draw on my battery. Went out 3days ago and the battery was dead, put the charger on it and she fired up. I got out there and pulled off the - battery cable and put my multi meter leads on the -battery post and the other on the cable. It read -11.37 volts with the key off. That does mean that it has a draw on it doesnt it?
Viperwolf1
electron whisperer
Yes, it has some amount of draw. It's more important to know how much it is. Even the smallest draw will show voltage drop. Use an ammeter and measure it.
Good test, wrong setting. Amp measurement, not volt. With a digital volt meter you can get that much of a reading with just the resistance of your fingers.
Once you start reading amps then disconnect stuff until the reading drops off. Clock, computer and radio memory will have a small amount, a few milliamps.
Some of the common items that pull dark current include the alternator (bad diode), voltage regulator, ignition switch, ignition module. But it can be nearly anything that has a connection to the battery. A common thing is to pull fuses until the draw goes away. Only a few fuses in a Bronco to try that with, but still a good diagnosis tool.
If you have a test light put that inline like you did the meter. If the light is on then it will show the drain on the system. It will be insensitive to the computer memory but will show the big current drains that kill a battery in a day or two easy enough. Same testing as above, just look for the light to go off to show you found the problem.
beaux312
beaux312
Hartford, AL
I will try that tomorrow, I relize that I didnt do anything exept complete the circut and read the voltage in the battery
