Ignition switch, battery draw question
4via4
A couple of weeks ago, after driving my ‘75, the engine would not quit running after turning the truck to off. The gauges would go to rest, but the the engine would not stop, even by disconnecting the positive lead of the battery cable. After searching, all leads seemed to be a bad ignition switch.
I installed my new ignition switch today using the same connections and now I get a definite spark when connecting the battery which wasn't there before. I double checked all connections and made sure headlights, etc were off. What could my problem be and where do I start looking?
Thanks,
Joe
Steve83
To help you, we need to see ALL the truck's details (year, engine, trans, options, modifications, which parts are original, which are replacements including brands/PNs/sources...) in your signature, and pics of what you're working on. Exactly where does this spark occur (wire colors, connector pin numbers)? Study this page & the NEXT several:
(click this text)
4via4
It's a 1975 with a 302, automatic, no mods. I'll study the wiring diagram.
Voltage regulator can also stick and backfeed the ignition (they are turned on together)
Unplug the regulator and try hooking the battery up again.
Note that if you have a modern radio installed they typically have capacitors that will charge up on the initial battery connection. Little spark at first contact. Lift and install again and no spark the second time. That is normal.
Rustytruck
most of the times I dealt with this it was a starter solenoid issue or the ignition switch issue. the ignition switch contacts are a wiping contact so if you turn the switch on and off several times the issue usually goes away unless its the contacts in the starter solenoid problem..
You can tap the starter relay/solenoid too, and that often "fixes" things. Temporarily...
But to narrow down just what it is, fire it up, turn the key to OFF and if the engine stays running remove the small Brown wire from the right side "I" terminal of the relay. If the engine dies when you remove the wire then you need a new starter relay.
Try not to do that test if you can avoid it. It's dangerous to the alternator.
You know that the major key function for the Accessory side of things is still working. It's possible that it's not working properly for the ON side, but it's not very likely. More likely is what someone said about the voltage regulator backfeeding the wire to the coil.
The two wires share the same terminal on ignition switch. One is Green w/red stripe (regulator and a few other things on a '75) and the other is Red w/green (ignition coil and ignition module) so can mess with each other. It's rare-ish, but it does happen.
So if removing the Brown "I" wire does not kill the running engine with the key OFF, remove the plug from the voltage regulator and see if that does anything.
Probably a good thing to check Steve83's diagrams anyway, just to make sure that a '75 does not have any other things in the circuits that could keep the ignition working with the key OFF.
Since a spark while connecting the battery cables is somewhat normal, I would not worry overmuch about it just yet. If it was a big spark though then checking the key and the lights was a good thing to do. But if it's still there then you know that something is working in the background still.
The problem with replacing a part these days however is that you never know if you just added a new problem or not! New parts are often crap, and a crap shoot.
Do those other two tests (removing the one wire from the relay and the connector with the 3 wires from the regulator) and see if that cures the issue. Do one at a time of course so that if it works you know which one was the culprit.
4via4
Thank you all for the help and advice. After studying the wiring diagram and removing one component at a time, I found my alternator to be defective. I installed a new one today and am back on the road with no more sparks when the battery is connected. Joe
Fantastic news! Glad you got it fixed and running like it should.
Good detective work by the way. After that, and with diagrams in hand you'll be a wiring expert!
