BC Tie Rod Conversion "Under"
Bronco_46256
Elkhart
Truck:
'76
Stock Height
Stock Power Steering Box
Stock Pitman Arm
Stock Inverted Y setup
Daily driver
Highway miles
0% off road.
Question:
1. Can the BC Tie Rod Conversion # 47-00311 be installed in the "Tie Rod Under" configuration using the tapered Heim Stud?
2. If it can be installed in the under position, will the taped studs fit in the stock, unmodified tie rod holes?
Asking because:
Time to replace the stock setup due to number of miles driving the truck. I want to buy something to cover future lift/upgrades but would like a system to drop right into place....I know, asking allot. Backup plan is the Wild Horses 3 way adjustable, but this looks interesting IF it'll drop in.
Pokey71
For a street driven truck, stay away from the hiems. Just stick with TRE's
joshd1971bronco
Oklahoma City, OK
Chuck from BC will likely chime in, but from my research, the BC heim setup will NOT fit the STOCK 76-77 steering knuckle tapers. The 76-77 had SMALLER tapers than the earlier broncos. So, you would need to ream out your holes (sounds bad) from the bottom since you're wanting a tie rod UNDER system. At that point though, since you'd be buying a reamer, I'd go ahead and make it a tie rod OVER setup and get the benefits.
The WH OEM style setup should work (if you get the custom T-style setup for the 76-77 years) and should drop in. You will have OEM style tie rods and OEM strength (way less than say a DOM / heim joint setup).
Depends on your plans for the vehicle. Since you say 0% offroad and you want something that will bolt right up, I'd say go with the WH custom T-style three way adjustable setup for the 76-77. Should drop right in (though I'd call to confirm - nice guys there at WH).
broncnaz
X3 just stick with stock replacement or direct bolt in T style stuff for 100% street. Even with a lift and bigger tires in the future the stock tieords are fine. Its only when you do hardcore wheeling with large tires and a front locker when you really have issues with the 76/77 tierods.
mortimersnerd
x2 on what Josh said. I'd probably swap out to the earlier parts given your priorities, but if you're not going with much lift down the road a direct replacement would be fine as well. The other option you have is to do a DOM/1 ton TRE install. All the benefits of both a much stronger DOM install with none of the down sides of heims, and massively stronger than stock. I did a write up of my install here:
http://classicbroncos.com/forums/showthread.php?t=179150
All of that said, if I wasn't ever going to take it off road, I'd probably just stick with stock unless you like fabrication.
trailpsycho
Chris, I have all the stuff to do a Chevy TRE setup over or under. I bought the reamer, drill bits and taps to make future setups. They are at Ron's and we could build them there or at Dan's. Give me a shout.
As well, I ran the 3way adjustable setup from Bronco Parts of Sacramento (now defunct) for 7 or more yrs. Its a good setup and likely the same as what WH or JBG sells.
Shout at me tomorrow.
