I have the 76/77 T-style steering linkage kit from Tom’s Off-road. I installed it maybe 6 months back with rough adjustments while the truck was getting built. I left everything loose for the shop to final tighten, align, etc. (trailer ride to the shop, not driven)
I decided to tighten the tie rod castle nuts and add the cotter pins since the shop doesn’t need to touch them during install but I ran into a problem. The cotter pin holes are too low on the threaded pin coming through the steering knuckle. In other words, the hole is not accessible for a cotter pin to pass through. I have since stripped the threads of both outer tie rods trying to get the castle nut down enough so the cotter pin hole is accessible.
Complicating my situation - I have NO CLUE for the tie rod part numbers to replace them. Any one help me out here?
I know it’s a 77 EB D44 housing with the stock knuckles. Do I need to ream the knuckle?
Thanks to all for the help!
@tomsoffroad76
@tomsoffroad76
