Best engine for a daily driver Bronco
Greg Bell
Hey guys,
I have a 67 Bronco with a 289, headers, Edlebrock carbs, etc. It seems a little "cammy" so I suspect it has been internally modified. It gets about 10 mpg with a mixture of highway and short stops.
Down the road I plan on rebuilding or dropping in a crate motor. I am not planning to do any extreme off-roading--only more limited hunting and backwoods trips. What would be the best motor for this?
1. A rebuilt to spec 289 with electronic ignition but otherwise stock.
2. An FI 302 set up for a more modern truck.
3. A 351 carbed
4. A 351 FI
5. ????;D
Any thoughts?
tcb42
I Did the same thing you are doing when it was time to rebuild my 289. After researching rebuild, stroker, 351,and 302 crate it was cheaper and easier to go with the crate 302 from Ford Racing. At the time about 3 years ago I got the 302 from summit for about $3,400. Now the same engine is about $4,900. But I think it is a nice balance between a mild modified motor and a DD. And it is all new not rebuilt too.
Oh and go with the efi. So my pick is #2. Hope this helps.
ugly74
Bronco abuser
Colorado
chevy 350! hahaha jk. I'd shoot myself first.
you can rebuild that 289 into a perfectly good DD. no EFI needed. get a torquey cam, and a modest sized carb, and yer good to go.
but if yer right footios real heavy and you like to drive like an Ahole (such as myself) then bigger is better. a 300 six can tool around the roads all day long, but a 427cid small block will too. how much power do you want?
broncnaz
Just a cam swap may be all thats needed. You can call a cam company or two and get a cam matched to your vehicle, gearing, and driving needs, Then you should get the most out of your setup.
FI is nice but you'll be spending more money and it doesnt always result in any mileage increase.
Depending on your current setup I think you should be able to pull around 14 mpg with the correct cam and good tuning a electronic ignition is a big help as well.
wildbill
Old Bronco Guy
:D :D :D Im not that old yet I would go with a nice 351W and RV typ cam. I just love the torque it makes. When I get real old I mite go with a stock motor But I will need to be real old then good luck with your choice.;D ;D ;D Bill %) :cool: ;D
AGShelby
San Antonio, Texas
Do the Rebuild !!
I went with a stock rebuild on the original V8 with an RV cam. Total cost for the rebuild on the long block was 800.00 - parts and labor. Got it back from the machine shop as an assembled long block and built up the rest in a few hours. I added an aluminum intake, 600 cfm carb, stanless headers and electronic ignition through a billet distributor - and came in at about 1800.00 total.
Crate engines are great - but you can save some serious $$ by rebuilding and doing some of the assembly yourself.
FI 302 out of a car, not a truck unless you get an Explorer 5.0 then I guess that is a truck but you will want car wiring and computer to keep it simple and loose the OBD-II stuff. The normal truck EFI is too tall to close the hood, car intakes are usually just short enough to fit under a Bronco hood.
FI is great for daily driver. Turn key start.
If the current 289 feels good, the FI 302 will be fine. If you want more grunt, the 351W will do
G
Greg Bell
The current engine is fine with me in terms of power. I guess I am old at 36! :0
tejayandtina
Cheapest route would prolly be rebuilding the 289, although if it's to "specs" then you'll lose some of the power you have now. It depends on budget and time. 302 FI are to be had, but takes time to plan, acquire parts, and install. Not to mention the increased time/expense of setting up fuel delivery for FI, stuff like that. Sounds to me like going with a 351 is out, won't really help with mileage, don't need the added power, etc. Based on the info, I think you'll be happier rebuilding the 289, with a milder cam, and keep it carbed. Good luck!
blubuckaroo
Grease Monkey
Ridgefield WA
Overhaul the 289! In base form it should get the best mileage possible on these things. FI has it's rewards but there's nothing like seeing the carb under the hood! Nothing unique about FI anymore. I'm looking at the same issue with my later 302. I plan a basic rebuild a 302.
rhino2104
FI CAN improve driveability but I wouldn't say that it would hands down. I've had carb'd vehicles that would start no trouble. I let my old truck sit for 4 years while I was in training and stationed overseas. I went home, put a new battery in it, pumped the gas pedal twice and she fired right up with no hesitation at all. And yes she was carb'd.
With what you are saying it sounds like rebuilding your 289 is the best idea for you. It should give you a mileage increase if you pick the right internals and still give you plenty of power.
SeaninSt.Cloud
anything dependable and that you are able to fix with your basic tools when it breaks down-any stock engine with carb. I try to stick with KISS-Keep it simple .........The more complicated you make it the harder and more expensive it is to fix IMHO
markperry
I would checkout gearhead.com I don't believe you can rebuild one for the amount of money they would charge for a re manufactured engine. They are extremely fast at getting the engine at your doorstep, if time is an issue with you they can get the engine to you in about 3 days! Just my 2 cents!
ep67bro
Bronco Junky
Easton, MD
I am a fan of the 289. Stick with that with a mild rebuild and you are good to go. I have had 289 in a mustangs and currently have one in my 67 bronco and it is a great motor. I think it is the strongest motor out of all of my broncos and it also runs the best and gets the best fuel mileage. But you cant go wrong with any of the ford small blocks. Also if you already have the motor then you dont have to worry about anthing fitting or the wiring nightmares of fuel injection. Build the motor out of a summit catalog, mild edlebrock cam, performer intake with a 500 cfm carb some long tube headers and you are on your way.
LilRedBronco
Belmont, California
I have a mildly built 302 w/carb in my 72 and it has plenty of power... On evenish surfaces... Once I start going up some of the hills in this area it kind of struggles with the 35 inch tires and gears. I am going with a 351W long block as soon as I can find a goodun at the right price and will build the rest. A 408 stroker would be fine too.
I'd say go with a 351W it isn't going to be an unmanageable beast and for the mud and backwoods stuff you won't have to really work the stockish 302. I'd rather have an engine that wasn't having to run full tilt to accomplish many of the missions.
FI is unnecessary with this mild weather here and even when we lived in Utah I never had troubles starting it. FI more complicated than I want in an Early Bronco
