Any drawbacks on the swap to 351? I guess size and fuel efficiency are the only real negatives right? I'm not TOO hung up on efficiency but if we're talking the difference between 15MPG on the 302 and 5MPG on the 351 maybe i would be.
I've heard they're a bit tighter fit. Any issues with specific headers, 4x4x2 box, etc.?
Only other consideration is cost I guess. How much did the 351W at the junkyard run you? Should it cost about the same to rebuild once I own the block?
Sorry for all the questions! I really do try to research and read up on all of this myself, but sometimes it's easier to just run with a train of thought! Thanks guys!
If you drive it nice people have reported actually getting better MPG's due to the motor having to work less or running a low RPM. Headers should fit, motor isn't close to the power steering so it should be fine.
I paid $100 for the short block I got from the yard and another $100 for the cylinder heads off an Explorer. I left the factory truck cam in there and it pulls like a freight train with 37's and 4.11's in 2nd high range. Plenty for me I'm doing, plenty for damn near anything.
Great point- with an added cost the 351 can stay cool...
Adding cubes to the 302 and additional friction from the stroker will add some heat, but I have no issues with heat on the efi 5.0 I have now, so I should be able to use the exact setup on a 347...
I a, just looking to see if there is a good 347 setup to run targeted at something other than a Mustang. The easy answer always seems to be- start with a 351w. I guess I am just a glutton for punishment, but I like the idea of the 347.
Todd
I'm running a junkyard 351w, junkyard heads, junkyard explorer serpentine, junkyard 4.0 radiator, 5.0 fan, original shroud and no matter how hard I push it I couldn't get it over 200*F. I just cant see spending the money ($700+) on a stroker kit just to fall short of a factory option.
Ask yourself this - what can a 347 do that a 351w cannot? (in how you are going to use it in an EB)
