best performing engine for a bronco?
Viperwolf1
electron whisperer
Keep in mind that more torque will result in more future drivetrain breakage. In other words, the spending doesn't end when the stroker is installed.
bsquared
The 96 5.0L Exploder I put in a couple of years ago has all the giddyup I'll ever need. (maybe 270 HP?) GT40 heads, stock (RV) cam and I went with Edelbrock performer intake and Q-jet carb for simplicity. EFI is in the attic and I may do that upgrade in a year or so.
From what I've read up on the 351, it is also a great platform but a little tighter fit. Good luck on the build!
so what is so special about the coyote engine? whats it going to do that another engine wont?
It is being touted as the next step in engine evolution. ford's answer to the GM LS line, and rumored to be better then the LS engine as well. Power and effiency. I have driven a few, the truck version is a bit lame but the mustang version reminds me the first time I was in a fast car back in the 80's. Back when 80HP was a common car and a friend had a mustang GT with over 200 HP. That was amazing! today every little econobox is pushing 150 HP at the bottom end and 200 HP is a basic car engine. The mustang Coyote is 400 HP and a few little changes will make 500 HP.
This of it this way, take your wore out 140 HP smogged over 302 and step up to a late 80's 5.0 mustang engine, huge jump in performance. Well take a bigger step and jump up to the coyote. All the same size, but you are now trippling the HP. And it can be done cleaner and (if driven the same) on less fuel.
Now I will admit that it does lack the big low end torque of a huge inch motor, but it will wind enough you can make up for it with a bit more gear. just make sure you get a transmission geared to match.
B
buckenbronco
Hanson
after calling and talking to stroppe about the coyote engine. they have made all the adaptors, engine mounts, headers and just about everything to put this engine in. i think thats the direction im heading. the coyote engines cost the same as me having a 302 or 351 one built. stroppe says they run great in the broncos.
broncnaz
Dont know how you figure the coyote engine cost the same as a built 302 or 351 guess the only way it would is if your are looking for the same HP numbers. I still like the simpler engines all these new ones with cam phasers and varible cam timing may be nice to have when they are new but as time goes on parts wear out and problems arise and they wont be cheap problems to fix.
To me for the most part the coyote and other small displacement engines are fine for cars where you can cruise around then open them up but for a 4wd they dont impress me as a engine to have as most of there power is made way up there in the RPM's.
And that sounds just like the first arguments when someone wanted to swap in a mustang EFI engine into a Bronco. I remember people didn't trust eletronic ignition and would take it out and put points in%)
trailpsycho
I like my 96 Explorer EFI 5.0 , it makes enough power...well almost. It runs great. I installed a Crane aftermarket cam. I have had several conversations with folks about my frame off and what I would or wouldnt do different.
Over the 4+ yrs that its been back on the road, I've been pleased enough to say not much. Sometimes, I would like to have a bit more of the "seat of your pants feel", which I can definitely get out of it sometimes if I shift it higher and rev it a bit more...but I would say that a 351W with aftermarket heads TFS, Edelbrock or AFRs with EFI and matched injectors and tune would make an ideal motor. Hell, I would like to get rid of my GT-40s for some AFRs, I think that would make a nice improvement. BUT a 351 with a solid performance cam and aftermarket heads and EFI would be my recommendation. You can probably get it built and install it yourself for about $6K.
I think the 4BT would be a cool option, if you can handle the noise.
The Coyote would be awesome, but I think it is a few more years before it becomes readily available, but probably not terribly affordable. I would guess that you are looking at somewhere in the $10-13K range...maybe more by the time its tuned and installed by a pro...because there is really no aftermarket DIY support at this time. It is the bee's knees and priced accordingly.
The great thing about the 351W with EFI, is there are a ton of books, build-ups, tech support, aftermarket parts and DIY info all over the net.
I love to see a nice Bronco out. And I think its great when people REALLY drive them, but if you didnt build, install or understand the tech behind it...are you really going to feel comfortable beating up on it in the middle of nowhere.
The biggest pull to the Coyote is the potential for significant fuel efficiency gains. It doesnt surpise me that a properly geared 351W is more efficient on the highway than a 5.0...the 5.0 may not be in the ideal torque band to push the big box thats jacked up and on 35" tires. I think I would get better efficiency with a comparable 351W...keeping everything else the same. For whatever that is worth. Do I have plans to change it anytime soon? No.
So, go with whats in your budget and your skill-set. If you are a DIY kind of guy, then I think youve gotten alot of advice pointing you at a 351. If you have the budget to spend alot more and are in a market where there is expertise on the Coyote to help you install and set-it-up...then OK.
I got into Broncos because I wanted to be able to be self-sufficient with it. Work on it, know it inside and out. Know that I could take it from one end of the country to the other, E/W and N/S and never worry about would I know what to do when something breaks or a part goies out. I think thats why alot of us are into this hobby. It seems there is alot more money and flash in the last few years and I suppose that is OK...but its kind of like the people who enter triathalons...but dont know how to change the inner-tubes on their bikes...who rides 20, 30, 40 or 80 miles out into the country and doesnt know basic bicycle maintenance. Its the same with a classic truck in my opinion....especially a modified one...how do you expect someone else to know what's wrong with it, if you dont know or understand what's in it?
Sorry to get preachy. Long day. Good luck with your choices. Have fun and make it your own!
Cheers!
John
Amac70
ME
so just a quick google search and the coyote can be had for a little over 6k with everything but the pcm and front dress. mounts the same as a 4.6 which there are motor mts for a bronco for. then you just need a tranny to bolt to it. another couple of grand. sounds like about what i got into my 351 efi and 4r70w.
bknbronco
North Metro, MN
For 6 grand id rather have another bronco with the stock 289!
After not having a job for 3 or 4 years you start to enjoy not working and not having any money isnt a big deal. You learn whats really important in life.....and a big HP motor isnt important to some. Id rather have a few shitty old vehicles than one nice one.
Amac70
ME
different folks want different things. i love my truck do i want another hell no. It would be like haveing a mistress i pay for but never use. id rather have one that is well built, turns heads and does what i want even if it is fickle sometimes. sinking 6k into a old motor is nothing, 6k getting a brand new block with warrenty from the manufacture well that is just spending wisely.
broncnaz
I
John
Gas mileage potential draw? Well you might get slightly better mileage than a 351 and have more power once your in the RPM's. but in a mustang they get around 25mpg.(only slightly better than say a 1992 mustang 5.0 which is a common swap and we all know nobodys getting close to that in there bronco) In the F150 which is a detuned coyote engine and probably better suited for mileage they only get around 20 mpg. Throw that engine in a bronco and your probably back down to the mid teens maybe high teens if your lucky. really not much better than what a well tuned old V8 will get.
Im probably a little to set in my thought process of course its kinda more geared to my wheeling kinda dual purpose street and trail nothing to extreme. but can get there and back with little worry about something going wrong and having to find parts. I like things simple and well old school.
On the other hand at least its a Ford swap so that gets some points.;D
fungus
Kaneohe Bay, Oahu
I throw my $.02 into this if its even worth that...
I was at a crossroads with engine selection for a project last year. I had a '90 5.0 on the stand I was going to build into a 347 for a crawler project. I picked up an F4TE roller block for $250 and S canned the stroker idea. Reason for me was overall cost and end game.
I built my NICE 5.8 for about 1/2 the cost of the 347 & I still have power options down the road if I ever rebuild it!
Its a Bronco. The BEST part about them is they're SIMPLE. Keep it that way and all your trail experiences will be good ones. The coyote is a sexy idea but having to turn a wrench on one in some precarious position on the trail is NOT!
I wrenched on my 6.0 diesel myself and DID NOT enjoy it! The stock Ford MPFI system on the venerable small block (5.0/ 5.8) is relatively simple and still leaves plenty of room in the engine bay to get around not to mention parts are only as far as the closest parts house if not in your toolbox.
Go with a nice 351, stab it in & DRIVE!
trailpsycho
You can look at my sig for my configuration. I am probably heavier than many due tothe galvanizing, full Line-X treatment and extensive cage and storage...guessing at or a little over 5K lbs. The reality is that I see 12 consistently driving aggressively or putting around town. On the highway, I can get 14, maybe. On the interstate, despite the good gearing and the overdrive, I am not quite in the optimum powerband at 70-75...so I have to put a little more skinny to move it ont he hills. At 80, its a beast and will climb, dance and sing, but its also drinking gas like gatorade and I can see mileage closer to what I get around town than what you might expect for highway driving. Its aerodynamics. A bit more torque and it would probably pull a little better at 2200 rpms, hence why I recommended the 351W. The torque profiles that I have seen from the Coyote and new ecoboost engines is available much lower in the rpm range, so you can get away with keeping your gearing up and having the power at those lower rpm ranges. This is where they are more efficient then our 302/5.0 and 351 counterparts of yesteryear. I like my 5.0, dont get me wrong, but if I could do an engine swap and have the same torque and power just off idle and full-on by 1600 rpms, that would be awesome.
As far as only upper teens, compared to my 12 mpg, thats a 50% increase in efficiency.... At $4/gallon, thats a huge savings for a driver. Hell, I would love a 20% increase. 15 mpg in town and 18-19 on the highway would pay for itself in a couple of years, if you drive it. Doubling your fuel economy, that would be incredible. I think those sorts of powerplants will come eventually. Another aspect to our Broncos, is the axles themselves. I have read and was told by a tranny specialist that the 8.8 is much more efficient than a 9". There are several ways we can improve these trucks is my point. Old school is great...I have one, I built one, I love one, but at some point, if you are going to rebuild or upgrade and you can use something with comparable or improved strength, power or efficiency, then why wouldnt you move on to the newer tech. That may be the only way to realistically keep these rides on the road--and use them--or at least afford to use them.
Just shit to think about...
Timmy390
Conway, AR
I say it all comes down to budget. How much are you willing to spend and is it really worth it to you. Fast and loud/big and fancy is way cool but it cost money.
To keep the budget in line, I would go with what fits and uses most if not all the stock parts you already have.
If building a show/race truck, then the sky is the limit. Hell, dream big and go for it.
My 2 cents....I would take the 351W over the stock/stroked 302. I hope to get started on my 351W swap next summer.
Tim
broncnaz
Oh I've taken a lot of that into consideration. Tall lifts, big tires and the aerodynamics of a bronco all suck the mileage factor down. Yes a 9in axle takes more power to turn than a 8.8 but few people will want to run a 8.8. in the end even if you have a fairly stock height bronco with stock sized tires its areodynamics will be whats holding it back.
My reviews of the dyno charts for the coyote and the eco boost and the 5.0 truck engine all say they have less lowend then a mild 351 and I've seen some mild 302s with better lowend numbers.
I just dont see any of these engines really getting better gas mileage than the engines most of us currently run. My 73 with 33in tires and a carbed 302 can pull 16 mpg at 65 mph. Quite a few guys running EFI still dont pull that good of mileage. Again lift and tire size doesnt help mileage in most of there cases.
On the flip side the engines your talking about do put down good overall power numbers good for the race track or if you intend to have the turbos spun up all the time. but IMO its just not where we need it in broncos.
Revelation
After my 300 I-6 swap, I will not own another Bronco without one, PERIOD! And the EFI will be on soon. Been running 2 years and 16,000 miles on the ol 1bbl, she gets about 18 Highway, and on trail rides uses about 1/4 of what the v-8's do. Yea I am getting old and like my torque on the low end of the RPM range.
Jules82
I'm a newbie here I have a 82 gt mustang 306 62 mil turbo mustang 650 HP. Building a 70 bronco now going 429 cobra jet carb lol crazy but I want to be different. I can't find anyone else that has done it I put a 460 in my CJ7 10 years ago loved it. Just started on it I have engine all done 600 HP 876 T probably to heavy but ?
Sent from my iPhone
Thunder26
That's what the variable valve cam timing is for... It's like having an RV cam and a big race cam in the same motor. The only way Ford could make a better engine honestly would be to make that variable cam timing and lift.
