Heus33 said:
I've got a set of bumpers on my rig that I'd like to remove. Problem is they're welded onto the stock bumper locations. I've tried a 3" cut-off wheel but it barely made a dent after about 10 minutes and made the tool so cold it was frosted over. Am I using the wrong tool or wheel? Does my compressor need to be set at a certain psi? Am I approaching this all wrong? ?:?
Not knowing exactly what is welded it is hard to tell if you are having a problem. Tips for abrasive cutting; Make lots of sparks. the more yellow sparks you make the better it is cutting. This tells you how to work the tool. Add more pressure, make more sparks. Too much pressure and the tool bogs down, sparks go down, and cutting slows down.
Different tool. I don't like the 3" for heavy cutting. I use plasma when I can. Sawzall works good too. Another favorite is a 4½" grinder with a matching metal cutoff wheel.
Depending on how it is welded, couple of tack welds is different then full beads all the way around.
