Better pully options for 3G Alternator
ljspop
San Marcos, Ca
Short of going full blown exploder serpentine, are there bigger pulley options to help keep a 3g alternator from squealing? I have the belt probably too tight now and it squeals at start-up pretty consistently.
Any one have a bigger v-belt solution? Or something that doesn't require replacing the timing chain cover forward? That doesn't cost a stinkload of cash? Asking a lot I know, but just wondering if the collective knowledge here can save me some $ and time.
Thanks,
Bob
Explorer
Raphine, Virginia
Just changed mine for the same reason. But I already knew the pulley was too narrow for the belt. Make sure it's seating in the pulley like the rest of your pulley's.
With the right mix of parts you could probably run a double V-belt setup. I remember our '67 mustang had that.
The problem is a 3G makes so much power. Well to make that power it takes it from the belt. A single belt can only transmit so much power. The 3G is known for being right at (usually more of slightly over) the limit.
To get a single V-belt to grab the pulley a little better it needs more surface area. Generally this means a larger pulley. Now a larger pulley also has the benifit of more leverage on the alternator shaft. Down side is alternators are very sensitive to speed on the low end. Just a few RPM can be the difference between charging at idle and not charging at idle. The larger pulley that has more surface area and better leverage may not spin fast enough to charge.
dbevans2249
Buena Park, Ca.
I put a pulley that is a little over 3" on mine and it seems to work great. It puts out plenty at idle and did not squeel when I fired it up. Look on Ebay, Summit etc to find one you like.
JohnJohn
Richmond
I had the same problem and put a Top Cog belt on it has the bumps on the outside of the belt and it fixed my problem.
It was suposed to be the best type of v belt they sold. It may be worth a try.
Also make sure your pully clear of the alt body.
I had to put a washer on the back side to get my v belt pully to clear after I pulled the serp pully off.
Smokeater11
Auburndale,FL
I vote for a good quality belt as well. I have the 3G and it would squeal at start up every time until I switched to a Gatorback belt and the squeal went away.
ljspop
ljspop
San Marcos, Ca
thanks guys. I'll try a better belt first before i try pulley swapping. dual belts sounds interesting, but with PS I think there would be a need to change bracketry.
backpain
Assuming mostly stock configuration: You can find acceptable dual PS and dual and triple crank pulleys if you wanted to get inventive with a multi-V-belt setup. Also, the PS pump pulley can be made to work if your system can handle the slower RPM/lower output. May require trimming a sleeve or bending a bracket to get the offset lined up appropriately, but definitely can be made to work.
