Biggest Pain in the Butt.....
broncoitis
thing that you have had to do on your Bronco?
For me there are probably a couple that could qualify but as of right now I am not really enjoying the process of cleaning up the bottom of engines gasket mounting surface to put the oil pan back in place. Especially since I put studs in there when I built the engine. Seemed like a great idea then. %) However now, removing the ones at the back of the engine are damn near impossible so getting it prepped has been a pain.
Any others have some things the love to hate while working on their BRONCOS? ;D
casadejohnson
Bronco Alchemist
Attempting to find the unknown cause of a problem. My recent " Death wobble" in my 74 comes to mind. Tightened everything up and it went away but I'm still not confident that its really fixed.
Fredly1
When removing my old core support I had to use a BFH and keep jerking it to break it free. I jerked it a little too much. It came up and hit me in the mouth. Next thing I knew I was spitting out broken pieces of teeth!
NY-Bronco
Resident Dipstick
Weehawken, NJ
just about everything especially all the sharp little edges all over the Bronco. It shod come with a warning - Dont stick hand in here!
And lower radiator hoses, especially when no where near tools or home ;D
blankenship76
Indianapolis, IN
The transfer case was a pain swapping out the seals, couldn't find them anywhere finally broke down and oerdered the kit after every store in town gave me the wrong ones.
Cleaning the entire bottom of my rig, with a wire brush sucked as well.
3rd would have been putting the body lift on, really gave my patience a test that afternoon.
71broncman
Maysville, Ky
The ongoing PITA of trying to get the dipstick tube to seal after pulling it out to install headers. I had to bend it some for clearance and it was tough to get back in and it still leaks a little. At some point I'll have to pull the pan again to address this(I hate oil leaks).
Mark.
RG801
Oklahoma City
Ouch!!!!
brocken
Seattle
A while back I would have said replacing the body mount bushings or getting my new transmission mated to the engine.
Now I would say the biggest pain was rebuilding the rear drums! Could be because the bruises are fresh and my hands still hurt.
Now that I've taken them apart and put it back together a few times it seems easy. But wow, that first time I invented new swear words.
Oh, and getting the carrier out of my D44 awarded me a nice bruise on my head.
1970mule
mine would be trouble shooting like has been already said. i can't stand not knowing what a prob is or where a stupid lil squeek is coming from. ARRRRRGGGGHHH.. if i can find it then i can have a good chance of fixing it.
Prizefighter
Axle shaft seals, the ones in the front differential. Seemed really bad this weekend, but I feel like I could rebuild my axle blind folded now.
fastcarkenny
Avondale, AZ
The most aggrivating thing in my build was shoehorning in the headers next to the C-6 and trying to get them bolted the head. didnt hurt myself, but I did do some cursing. I'm hoping that when my 4r70w goes in that they will fit in there better.
SACHEM
Back From the Dead
I hate small irritating things like ignition switch bezels and anything else under the dash.
