Bilstein 7100 rear question
valveamp
Will Bilstein 7100s fit on my stock rear mounts (1971), or do I need to change the bushings? If, what bushings do I get? Thanks.
JIMS74
PORTSMOUTH, VA.
The 7100's have a 1/2'" inner dia. spherical rod end and the stock rear upper shock mounts have a 5/8" outer dia. I ended up using prothane 19-919 shock bushinngs for the upper rear shock bushings without the provided steel sleeves wich are 1/2" I.D and 5/8"o.d.. I machined the the flange thickness of the bushings down to a 1/4" to allow for more thread engagement after these pistures were taken.
Jim
V
valveamp
Thanks for the information. That's exactly what I was looking for. I have 2 more questions, if you don't mind. First, how did you get the rod ends off the shock? Did you press them out then press in the new bushings? Second, how did you machine the new bushings? Thanks
JIMS74
PORTSMOUTH, VA.
The 7100's have a split retaining ring that hold the rod end in place. they need to be removed then the rod end can be pressed out. to cut down the prothane bushing, I bolted the bushing on a 1/2" bolt and chucked them up in a drill press, using the top of the vice as a steady rest for an utility knife to cut the bushing. I sprayed the blade and the bushing with WD-40 for lubrication. good luck.
Jim
AZ73
No kidding, I was just about to have the same problem. Thanks!
