Rear Bilstein 7100's
67 Halfcab
Getting ready to buy a set of 7100's and looking for a rear part number. Lee at raceshock.com sent me several options, and I am wondering which one is the best choice. My setup is Wildhorses 3.5" leafs and stock shock mounts.
Gonna get AK7112SB's for the front.
Here is what Lee sent me for rear options:
Bilstein AK7112SB 7100 Series 12" travel short body w/ RR extended length 27.68" / collapsed length 16.10"
Bilstein AK7112R06 12" Travel with remote reservoir extended length 31.10" / collapsed length 19.53"
Bilstein #AK7110SB02, 7100 SERIES 10'' travel short body extended length 24.31" / collapsed length 14.29"
Bilstein AK-7110R05 7100 Series - 10" Travel W/RR extended length 25.77" / collapsed length 16.10"
Which ones are you guys running?
What valving are you planning to use?
For stock rear mounts with a 3.5" lift we sell the 15" to 24" shock size. So that 19 to 31 inch shock is WAY too long for stock mounts.
Or if you want to bias it a little long so you get more droop than compression, the 16" to 25" size would work and not too much likelyhood of it bottoming out.
But as always, the only way to know with 100% certainty (a good thing when custom ordering shocks, depending on the return policy) is to set your suspension up at expected ride height and measure between the shock mounts.
You would expect ride height on yours to be approx. 9.5-10 inches between the bottom of the frame and top of the axle tube.
Good luck.
