Bizarre EFI issue
Dfroman
I have RJM harness with A9L computer(s)
Everything was working until recently.
If I plug the harness into the ECU in the firewall (fabbed an escape box where the fresh air vent was). the fuel pump does not come on. If I take the computer out of the box, everything works okay in most positions. This is where my confusion comes in, my assumption is I have a bad wire somewhere. The other issue is if I position the ECU in a certain way, the fuel pump runs constantly
So I have a non running fuel pump in the place where the computer was installed
I also have a perfectly running truck in most positions of the ECU laying in the engine bay.
I then have a constant running fuel pump in other positions.......
What wire or wires would cause these issues?
thank you
now that's a good one!
One thing that comes to mind is a failing motherboard too. The pump running constantly is a classic example of the capacitors failing inside the unit. Perhaps they're still working, but having overheated a few times are now loose in their sockets. Just a SWAG with no basis in experience.
The loose wire sounds plausible too, but other than a ground, I don't know which one to look for.
At this point though if the ECM checks out good I would just look at all the wires and connections. Bad news I know, but it seems reasonable to hunt down any other gremlins that are lurking and just waiting for you to find the current one, only to have another one pop up in a few months.
It does not really sound like an issue with the jumper wire to me. But I wanted to mention it in case others are not familiar with the old RJM and our current Ron Francis harnesses. This is where you put the wire in one position for an A9L (manual trans computer) or an A9P (automatic transmission) so that the computer reads it's sensor inputs correctly.
If you have not already, PM member EFIGuy here too. Or jump in on his Explorer thread even though yours is neither an Explorer setup, or one of his harnesses. So as not to muddy things up too much, maybe just chime in and point people to this discussion rather than bringing up the whole thing in their thread.
Lots of knowledge running around that other thread, which is why I suggested it.
Dfroman
Dfroman
I actually have 2 different computers acting the same way. one is a Napa reman and the other I just had refurbished by a foxbody guru here in NC. I will reach out to EFIGUY
I had it running and wanted to go around the block. it was running fine and then it started hesitating and backfiring and popping. I switched out the ECU down the block and it ran for a minute, very poorly still and then it shut off and now it will not fire. fuel pump runs as it should. I have a major issue and do not know where to start...... I appreciate the comments.
jmhend
Bad relay?
Bad ground?
Bad connection on the fuse block?
I am thinking it's electrical. You can fab a jumper and bypass a lot of the things I mentioned above just to test.
Remember divide and concour. Find an electrical point that's good and start from there. I chased a bad ground for almost a year.
Jason
Sent from my SM-N960U using Tapatalk
yakelys69
pin 22 is the ground that turns the relay on, goes to both the fp relay and self test connector. normally tan/green.
JeffG
San Antonio, TX
The part about it running fine and then it started hesitating and backfiring/popping is interesting. I had a similar issue on my EFI a few years ago where it would run fine but popped and backfired at random times. After chasing several things it turned out to be the in-tank fuel pump hose. The hose inside the tank was deteriorating and almost fully collapsed.
I had bought the tank used and the PO must have used regular fuel line instead of hose rated to be submerged in fuel.
There was a lot of gunk in the tank so I cleaned it replaced hose with Gates submersible rated and had the injectors professionally cleaned and refurbed. After all that it was back to running like it always did.
Dfroman
Dfroman
all responses are appreciated. First thing now is to figure out why it completely stopped running....
Timmy390
Conway, AR
OK so if I got this right......
You have 2 ECM's one remaned from NAPA and another form "a guy". So let say both are good....
Lets just say you have 4 positions you place the ECM in. Both ECM's act the exact same way in each position. Nothing different. Position one no FP, position two FP all the time, position 3 backfires and will not run right and position 4 runs fine.
I would suspect one or more "female" pins on the wiring harness are loose. The little clips that hold them in place break SO easy with age. I have one broken on my EFI. I have to be very carful when I plug in my ECM.
I would remove the tape on the harness and verify all the female pins are in place and being held in place.
Tim
Dfroman
Dfroman
You are correct except it was running fine until the popping and backfire. now no start.
I will check the pins for movement.
BanditBronco
It's getting worse that is good. Easier to fix that way. Let us know how the pins are looking.
Rustytruck
pull the computers out and contact EFI guy he can test them if he is willing. I don't know if he tests harness? other wise get out the multi meter and have at it. attach to both ends and start wiggling stuff. Have you looked for burned trace inside the computer caused by computer and wiring harness mismatch on transmission choice? there is a writeup on doing that check up.
https://classicbroncos.com/forums/archive/index.php/t-262141.html
Jdgephar
Not sure about your installation, but the computer type (auto vs manual) has to match the harness you are using. If not, you will damage the EEC.
If you ran for awhile with no issues (several days), then I agree on a bad connector somewhere.
Also, check the computer codes.
Sent from my SM-G981U using Tapatalk
His harness has the jumper previously mentioned. If you have one style computer, the jumper goes to one wire, and if you have the other type of computer the harness gets jumpered the other way.
Very easy to re-configure for the different transmission type ECM's
Dfroman
Dfroman
the gray jumper is connected (manual) It has been that way for years
EricLar80
The weird popping is usually a sign of the MAF sensor being jacked. Did you happen to unlpug/replug it back in while the battery was still attached? But it shouldn't change anything for the fuel pump. Unless maybe whatever is grounded out incidentally.
Did this just start happening? What led up to the fuel pump issue, or did it just start randomly? First place to check is that you have ground everywhere you expect there to be grounds, and no grounds anywhere else... No other way around it.
For fun, I would also check to make sure you don't have water trapped in any connectors or splices - specifically look at the wires going to the O2 sensors since they are down low.
Dfroman
Dfroman
I have no idea what caused the fuel pump issue. Everything was working fine. I had to pull the steering column to have it rebuilt (another strange issue)
when I put the column back in I had the non running fuel pump. while testing things I jumped something and burned up the trace on the original ECU. That is repaired and I have a reman ECU from napa. I finally had time to work on it again and now of course the fuel pump is no longer coming on...... The relays are working. I have power to the shutoff switch. Have power to the injectors, and pin 22
While searching for issues, I checked voltage to the TPS, ACT, ECT all are within cold specs. I was doing that to figure out the rough running that I was experiencing.
Dfroman
Dfroman
*****Update******
I traced the fuel pump wiring and discovered it was very loose at the pump. tightened it and the pump now runs (with the ECU not in the correct spot)
It would still not start so I verified power to everything and still no fire. I unplugged the spout and it fired right up. I plugged it back in and it fired.
I installed the ECU back into the firewall and I definitely have a short (pump and relays clicking on and off. if I move the main harness wires it changes behavior.
With all of this, should I be checking pin 22 wires?
so I think I had the loose wire, and a PIP going out???
Jdgephar
I would find and fix your short with the fuel pump first, and then troubleshoot if you really have any pip issues with the module on the dist.
