blasting
wesleydax
works ok, kind of expensive. will not remove rust. and if you dont clean the surface right before priming you can have adhesion issues. we stopped using it due to the price
englewoodcowboy
Lick Creek Restorations
I did, you can look through my build thread and see the results, as stagecoach stated... it has its place for sure, I cold only find a novice media blaster and did not want to risk warpage so I went with the soda blaster. I think dustless would be better, all are pricey, about $100 an hour and it took 13 hours to strip mine and I didnt have him waste time stripping items I was going to replace.
nick1975bronco
I do sandblasting because its cheap and I have all the stuff to do it. but you can also dry ice blast you could check that out I haven't seen it done my self yet. but I here a lot of guys like it because there is no mess, it all melts in a few minutes
broncoitis
I had mine blasted with baking soda. I liked the fact that it won't warp the metal but you have to clean it off because it leaves a residue on the body. I don't know if I would do it again because of the residue left behind that you have to rely on the painter to clean up prior to workin on the body. Hmmmm!
nickgp
I've done sand, soda and now dustless blasting on the Broncos. By far, the dustless system is the cleanest, fastest system so far. The set up was by far the most expensive to purchase. The crushed glass and rust inhibitor is not available locally(yet). While the crushed glass isn't too expensive, the hold tite inhibitor is, at aprx 250.00 for five gallons. In each pot that you do you only have to put a few ounces mixed with water so the sticker shock isn't that bad.
suthernboy
Greenville, NC
Have to be careful with the dustless, too. Buddy of mine owns a resto shop specializing in Mopar muscle, so mostly unibody stuff. They don't do the dustless themselves, but have done the bodywork for some customers who had it done before sending the car to them. Apparently the liquid can get trapped and hidden in body seems and crevices and begin seeping out weeks later. Especially when on a rotisserie. Its caused them some fairly expensive re-work.
I asked them how they strip, they said they carefully sandblast the areas they can (fender and windshield flanges, door jambs, etc.) and on flat body panels where warpage is an issue they remove the paint with a common razor blade and an orbital sander. btw -- Its amazing to watch the bodyman with the razor blade, he'll walk down the side of a car and the paint will come off in one long strip. Apparently its an acquired skill.
