Blinker fuse issue
Hinmaton
On my ‘74 trail rig, the blinker fuse keeps blowing.
I found the fuse for my cigar/map light missing, replaced it, and fixed the cigar outlet. Started using it and then the blinker fuse blew.
Every time I used the 12v from the cigar socket, the blinker fuse would shortly go.
I tried to figure out why and noticed the cigar socket was loose (so, bad ground), before I fixed this the fuse would blow in seconds, then after it seemed fixed. But would intermittently blow a fuse again.
So I pulled the cigar fuse, wiring and socket.
Seemed to solve the issue for awhile. Then I put new 12v sockets with dedicated positive and negative wiring, ran through an Spod type relay box.
Started loosing fuses again. While charging a phone, I went through two fuses in 4 minutes.
I have put 20 amp and 30 amp fuses in, but both blow the same. It’s supposed to be a 15, but I can find a 15 that size. The closest is an AGX 20 or AGW.
It’s possible that the 12v charging sockets have nothing to do with the problem, but the issue seems to happen around the same time as the use of them.
Any thoughts?
Hinmaton
nvrstuk
PNW
Sure sounds like a short upstream of the socket OR something else is drawing amperagenoff the circuit and when you connect anything else to it, it exceeds the capacity of the fuse (don't really think so).
Follow th + wire from the fuse that keeps blowing all the way to your cigat lighter outlet...not easy but...
1strodeo
Squirrel Watcher
Wisconsin
I can't help much with the issue as I'm having similar issues, but I can tell ya I use SFE 14 fuses (P/N BK 7821074) and AGX 20 fuses (P/N BK 7821064) from NAPA they're about .70 each
However i also invested in a $3 15A circuit breaker from the hardware store for use while troubleshooting; it's already paid for itself ;D
Hinmaton
Hinmaton
Not easy is right. Particularly for an aging Husky American guy. Laying on the floor, feet out the door one arm wound around the shifter, craning to look upside down and backwards at the backside of the dash...
I’ve looked through several of the better wiring diagrams and it looks like the two circuits are not connected. The cigar lighter is/was always live, while the blinker circuit is key on.
That doesn’t mean that something got hijacked / spliced or nicked at some point...
Hinmaton
Hinmaton
Interesting! I was thinking about the breaker idea last night. I had done something similar on an old 6v Willys wagon once.
Did you bypass the fuse or in place of the fuse somehow?
1strodeo
Squirrel Watcher
Wisconsin
I used two short lengths of wire with blade connectors crimped on and just wedge the blades under either end of the (blown) fuse
Hinmaton
Hinmaton
Brilliant! I’m doin that.
Hinmaton
Hinmaton
Done-
I’m driving it all week, we’ll just have to see how well that work around does.
bronkenn
Bronco Guy
Southeast Ohio
They're really not that bad to work on.
1strodeo
Squirrel Watcher
Wisconsin
Done-
Well it's not gonna fix the problem, but it sure makes troubleshooting easier
I'm not sure there should always be power to the cigar lighter, all the diagrams I've looked at where the cigar lighter connects to the light switch looks to be normally open position?
Hinmaton
Hinmaton
I'm looping back on this one-
Put the 15amp circuit breaker in, worked like a champ... for a bit and then it just kinda gave up or something. it would work every now and then...
It was a blade circuit breaker- so I had to kinda rig it in there. So after a weekend trip, I pulled the Bronco off the trailer and put it in my garage. Figured I'd look and see what was going on with the breaker. It was super hot! I didn't use the blinkers at all, bit it donned on me that the fuse controls both the blinkers and back up lights- and I did use those. I'm betting it's the back up lights, plus the PO had installed super bright halogen type bulbs that would burn so bright that they would melt the lenses.
I left it alone for a week.
Today I decided to dig back in.
I pulled the tail lights and started looking over the wiring specifically those related to the custom back up lights. Bingo- I found an exposed and burned positive bullet connector.
I cleaned and re-did all the connectors on both lights, and then with the tail light buckets out and propped up I check to see if the y worked.
Blinkers- check
Reverse lights- check
Reverse lights off / out of gear - nope!
The only way to turn them off, is to turn the key off...
It's a simple circuit, so I traced the issue back to the switch plug and the transmission which the two wires had melted together near the plug and were causing an intermittent signal if I jiggled it.
Buttoned it all back up, took a break and then ran and got another plug pigtail at NAPA. Wired it back in, turned the key, checked the turn signals and then checked the reverse lights by putting it in gear and running to check them out.
The lights were really dim, and then they just went out. Blown fuse.
I took the tail lights apart, took the buckets out and now it works again. They turn on and off with the gear selector, and the fuse seems stable. All connections are cool. So what gives?
I started screwing in one of the buckets while the light was on and found this:
https://www.facebook.com/Hinmaton/videos/10217176595029824/
Yeah- that's a problem!
I tried fixing it, but the socket died somehow. I tried diagnosing why, but couldn't get the light to come back on- something to do with the ground.
fortunately I have another un-altered set of buckets that I'm going to put back in.
geesh!
Hinmaton
74BroncoCO
I have heard the back side of the fuse box can corrode and cause these issue. I am also fighting a similar issue. But with the garage over 90 and the humidity the same, I have little desire to get out there.
...I'm not sure there should always be power to the cigar lighter, all the diagrams I've looked at where the cigar lighter connects to the light switch looks to be normally open position?
Misleading diagrams.
Cigar lighter is always hot. Yes, the headlamp switch circuit that shares the same wire as the lighter is normally open, but the cigar lighter is on the battery side of the switch. So it's always hot at the lighter, and the switch controls the dome lamp/map light only.
...I didn't use the blinkers at all, bit it donned on me that the fuse controls both the blinkers and back up lights- and I did use those. I'm betting it's the back up lights, plus the PO had installed super bright halogen type bulbs that would burn so bright that they would melt the lenses.
Backup lamps and turn signals are on a different fuse (F5) from the cigar lighter (F3). Switched power buss for F5 and constant power buss for F3.
I cleaned and re-did all the connectors on both lights, and then with the tail light buckets out and propped up I check to see if they worked.
You may get some to work, but it's not going to give you consistent results.
The lamps are grounded through the housing, which is in turn grounded through the body via the screws.
Is your body well grounded up at the battery?
The (reverse) lights were really dim, and then they just went out. Blown fuse.
Maybe. But maybe it just needs a better ground connection to the body.
The buckets themselves are isolated from the body by little square plastic insulators. The actual ground connection happens in the threaded holes and the screws. Probably pretty rusty and inconsistent I would think.
Just about any Bronco with it's old tired wiring still (especially if it's as tired as yours it seems) can benefit from a ground jumper wire from the housing to the body
Make sure the contact surfaces are clean, and run a short wire under the screw to either the body or the frame. Your choice, but the body is the most convenient, and should be a good ground path anyway.
Fortunately I have another un-altered set of buckets that I'm going to put back in.
That's a good thing. Fixing sockets is possible, but it's a pain. A new (or good used) bucket with workable sockets is a good thing and an easy swap.
So back to the other question, how well is your body grounded via the battery?
Definitely!
And definitely on staying out of the garage too!
A good cleaning is not a bad thing to attempt on our old fuse panels. At the very least all the fuses should be pulled, wiped clean and re-inserted after cleaning the terminals too.
But add to that a good brushing and check on the backside is a good thing.
If you need to scrape or wire-brush anything, just make sure the battery is disconnected.
Hinmaton
Hinmaton
In the end I don’t think the cigar lighter circuit had anything to do with the problem, just coincidence. There certainly is ground at the rear body panel, but yeah it’s spotty with all the surface rust.
Interesting thought on the fuse panel. I’ll just have to do this, as it’s nearly impossible to look and see if it’s needed. Being in the south east with consistent high 90 temps and percentages of humidity equal to the temp, it’s tough on everything.
But those super bright reverse lights:
That’s just no good at all!
So my reverse lights are back to stock, maybe the blinkers are good now. We’ll see.
74BroncoCO
I bought a small wire brush set for a dremel at O'Reilly's when I went in for fuses. By hand, I was able to spin the one inside the fuse capture area, but then the wire brushes started spinning inside the tool! I can't imagine what might have happened if I had it in the dremel at a bazillion RPM's! Anyway, a quality set might help in cleaning out the connections on the front side of the fuse box. Just be careful not to take off too much material. and wear safety glasses!
My question is then, what can you do to stop corrosion once it's clean? Dielectric grease?
Hinmaton
Hinmaton
That could work, but it could also make for a mess.
Just an FYI:
I did some research on dielectric grease.
The name is deceiving, the grease does not promote conductivity in the way one might assume. It’s sole property is keeping the contacts free of oxides and having a temperature rating that matches the conditions of the connection. You don’t want it to melt and run out, but you also don’t want it to be thick and gooey. It also wants to be clean and free of contaminants.
Grease is not conductive.
Hinmaton
74BroncoCO
Hinmaton - I came across the same findings after emailing Permatex. They said that the it is a high temp grease, so it shouldn't run out. But the connections need to be clean. When you make the connection, the parts should cut thru the grease to make the metal to metal contact. But this grease will coat the contact areas preventing corrosion. I use this on my trailer connector as well, but the contacts need cleaned better before it can work well.
Permatex does not make a conductive grease.
