- Apr 3, 2022
- 544
Working on a friends bronco installing new starter. New BP 302, Bronco C4 (used to be a 3 speed), 164T 50 oz flexplate. New block plate from WH for C4.
This is the second starter he has replaced. In discussing it, he said when he went to put the starter on originally, the starter would not fit flush into the block plate starter hole opeing...the opening in the block plate was slightly too small for the starter. He figured it was a bad cut and just carefully used a Dremel to enlarge the hole very slightly. Starter went in, bolted up, and worked great for a month without issue. The starter began making noises then failed. Inspection of the flexplate shows no wear what so ever.
I seem to recall that there was a very small difference in Block Plate starter hole sizes for some reason but cannot find it.
1. Are there two different size holes in the block plates for starters?
2. If he used the smaller sized blocking plate and enlarged it (it is a very small different in size) would that affect the starter?
3. Because the starter worked perfectly for a month before failure, do you think it is just a case of a bad starter?
