- Nov 3, 2003
- 47,846
First time I’ve seen one hitting the frame like that. Are you sure there’s not an extra plate welded on the top of the frame from the previous installation?
And are you sure you’re using the correct holes? I wonder if new holes were drilled originally, or if these are still the factory holes.
The factory holes would have sleeves already, and most do not bother to add the fourth bolt. They simply use three, just as the factory did.
Even though the Borgeson is a common swap, just looks a little different. Probably just my fallible memory at work.
Even though it’s a pain, can you remove the box and get some more pictures of the frame?
