Body flex over mounts
Spent
After removing the rusted floor pans from my '72 bronco I discovered that the "Floor Pan Support Rail" is flexed over both body mounts where it mates. Not real bad, just a little curve at same left side at each mount. The rail is not buckled and has no rust, so I do not want to replace it. I want to flatten the rail then reinforce it with an 1/8" plate on the top side. Has anyone experience this? What's your advice?
Thanks,
Leo
knack
I straightened out one rail while replacing the rusty floorboards on my '70 model. I welded a plate (must have been about 1/8") inside the rail to reinforce the body mount area - seems to work well.
Lots of galvanizing left on my rails - ventilate the area well when you're welding.
Dave
Both Broncos that I've worked on had rotted floor boards and rockers. I think the braces loose their box structure when the floorboards rust through and the sag. I straightened them with clamps and a heavey piece of tubing. haven't had any further problems. I also used a 8 foot straight edge along the floor from the bed forward to get everything paralell. One of them that was abused on the rocks actually had about an inch of sag and the doors barely closed.
Mikey
Ditto! I fixed mine by straightening and welding in 1/4" plates. Two of mine were actually cracked from some PO jumping the Bronc....or the PO was REALLY heavy!
S
Spent
Thanks for the help. I wasn't sure about the integrity of the rail but seems it will be fine after reinforcing according to your comments. Thanks again!
S
Spent
Next question. How do I straighten-out while still on the frame?
knack
Heating the rail with a torch and jacking up the body (while it was bolted to the frame) worked for me.
Thanks for this thread - made my Monday better! My project is a long way from completion, but at least I'm done with sheet metal work. ;D
garberz
Bronco Influencer
Conejo Valley, Ca.
I removed all of the floor, I jacked up the body from the rocker panels. I took a lot of measurements to get everything straight. Mine turned out great, I just had it Line-Xed. What a difference that makes.
