Body flex
rudy16
I have a problem. I am reassembling after paint and somewhere along the line my body has flexed. I don't know when it happened if it was when I took the top off or the doors or driving it up on the trailer. Any ways the pass door is half inch narrower at the top than at the bottom but the drivers door is spot on. I didn't reaplace any sheet metal just disassembled for paint. So which body mounts should I shim to get the tub aligned again or is this not the answer. If I am off half an inch my shim should probably be at least 1/4 inch, correct? anything helpful thanks.
Heus33
You probably just need to adjust the door hinges. If you removed the doors they dont just bolt back on - they require some careful alignment to get them back to the sweet spot. I'd start there first. Also make sure your hinges are new or in good shape - 40yr hold hinges will sag and cause you all kinds of problems.
Sporto
Agreed..Tom is right. The doors never just come off and go back on without major adjustment. There is the forward and backward adjustment along with the lateral adjustment. These can be corrected with shims, washers and lots of patience.
I typically get some help to do this task. Also there are ways to modify the hinges for quick release like a Jeep that will prevent this in the future.
Rich
R
rudy16
I've got about 6 hrs in fiddling with the doors I changed hinges around messed around and test them for slop. I finally took off the hinges n just stuck the door in the gap and that's when I went to the tape measure the door barely fits in with no hinges at all. It has had shims and all the things possible done to but the top corner of the doors starts to hit the beginning of the fender or jamb whichever you would like to call it. I'm too the pt where the opening has to be wider at least a 1/4 inch min.
Greg_B
Cohutta, GA
I will agree that the body can flex... I installed a WH 1" body lift kit a while back and the gap at the top of the passenger side door is now wider than at the bottom or the other side. Also.. my soft top doesnt fit like it did either. I can barely get the right rear to hook to the rail. I think I actually need to shim the right rear body mount to correct it.
Greg
needabronco
Prescott/Farmington
Try shimming the body mount closest to the door post it 'might' fix your issue if not take the shim out and try the passenger toe board mount.
Skiddy
does this help any
R
rudy16
I had an issue with the top not fitting correctly I had to force it into place then tighten down. It was also off in the back right post. I think the mount needs shimed.
Greg_B
Cohutta, GA
I put my hard top on when I did the body mount thing just because I thought it would help keep everything lined up.
So much for that.
Greg
chuck489
Dahlonega, GA
My door stick out about 1/2" - 3/4" at the bottom rear corner. My body shop guy, who has re-built a few Broncos, says that because mine has been run for a long time without a hard top the sides have given in some(think of the rear quarters leaning in toward the middle). He says he can fix by cutting loose the rear "wall" (inner quarter) and then rewelding it to the floor after he gets it aligned. I have seen one that he has done this to, but never watched the process. He says the doors will be able to be adjusted properly when this is done. I will let everyone know how it turns out when ever I can save up the money for the labor.
Scrapper_MV
Do you have a roll bar? I was able to add tabs to the roll bar and use bolts & washers through the bed rail lip to push the sides back out.
chuck489
Dahlonega, GA
I have a standard roll bar right now (with plans for a family bar soon). We were thinking about taking a trailer axle leaf spring perch and welding it to the roll bar, with the flat part against the body.
taipeichris
Skiddy, thanks for the measurement page. I just printed it and will keep it in the garage for later!
C-
Mr Rags
I had the same issue. I put a shim or 2 under the bodymount to get the door to fit.
