Borgeson Steering Box
dsmelfi
@EmmaBronc
New York
I upgraded my steering box to a Borgeson 4 turn. When installing I just dropped the pitman arm, but left it connected to the drag link. I centered the box and reinstalled the arm. Now my DS tire is rubbing my sway bar before I get to full lock, but my PS tire clears.
Running 4 1/2" WH Coils and 35s.
What are my best options to fix this? Wheel spacers? Adjust the knuckle bolt?
jscheier
Parker, Colorado
When you reinstalled the pitman arm, was it parallel to the frame, or angled slightly towards the driver's side front wheel? It should be angled slightly towards the DS wheel when reinstalled. Not my rig, but this is what I was told (and after installing, agreed) it should look like. Both DS and PS wheels have no contact with my swaybar when going lock-to-lock. https://share.google/WyGOHGWvrnXgTGLef
dsmelfi
dsmelfi
@EmmaBronc
New York
It's angled towards the DS. I have a steering stabilizer so if it was parallel to the frame the shock would be almost fully compressed with the wheels straight.
Jdgephar
Nothing about the steering box would make it suddenly make the tire rub if it didn't before.
If it didn't before, that means your previous setup didn't allow you to turn the wheel that far. Now you can. You need to figure out how to re-adjust so you have the same amount of turn as before.
Just a guess, but the previous box may not have been in the middle with the wheels straight.
But make sure that the sway bar is centered first.
Since a '73 did not have a factory swaybar (or "anti-sway bar") then it's aftermarket. Who's is it, and is it skewed to one side? Maybe it can move inside the clamps and just got pushed to one side.
Of course, it's all a system, so it's ore of an "all of the above" regarding checking things.
dsmelfi
dsmelfi
@EmmaBronc
New York
It's a helwig sway bar.. I will check that as well. Just by eye, it looks like the track bar needs to be adjusted.
The box is about 4 1/4 turns lock to lock and it's centered.
Thanks all for the help. I'll report back when I can.
dsmelfi
dsmelfi
@EmmaBronc
New York
So the trac bar did need adjusting, the axel was a little more than 1" off to the passenger side. My trac bar is fully closed now, had to remove the jam nut to get it to adjust that much.. now the axel is about 1/16" - 1/8" off, still to the passenger side. I have a drop trac bar bracket.. wondering if the PO installed it wrong or if it's tweaked. I have 4.5" WH Coils and a drop pitman arm.. so it feels like things should be lining up a bit better.
Just as FYI.. I also have JD t-Rex Evolution arms.
After adjusting the trac bar, the box almost locks without rubbing, but its still pretty close so I'm thinking I should do some wheel spacers just to get the full turn radius.. kinda dig a more aggressive look as well so probably add them regardless .
Anything else I should be checking here? I'm a little confused why the trac bar is fully closed with 4.5" coils, even with the drop bracket and pitman arm.
