boring a 351W
bronco-billy-66
Madison Mississippi
I bought a 351W out of an old 70's van in a junk yard, hoping it was standard bore....it was not !!! Bored .030 and the crank was turned .020-.020. I don't care about the crank B/C I'm gonna run a 408 stroker...I don't think .040 will clean up the bores, Is .060 to much for what i'm gonna do?...I don't want any heat problems...I do have an alm. radiator though.. Is honeing and re-ringing out of the question?
2badrotties
Just a Bronco guy !
Niskayuna N.Y.
A 1970 block is one of the most durable but I wouldn't go .060 on a street engine. BUT, you may look into re-sleeving it. It isn't that expensive and it is very safe if you have no cracks in the cylinder walls. If you have a really good radiator going .060 may not be too bad but if you don't upgrade the radiator I'd try and stick with .030 over. I guess it is a 50-50 thing. Some may try it, some wouldn't. Good luck with it :)
braxton357
morganton NC
Get another one. .060 is in the unsafe zone, and 351 blocks aren't all that expensive. (I picked up a fully machined to .030 over block and crank with bearings for $200 not long ago). Also, the strong blocks were from 69-74.
wildbill
Old Bronco Guy
;D ;D ;D I would go lookin for a new block as you will endup with a motor that will run very hot not good. They can be found out there good luck. :p :p :p Bill :cool: %) :p
ak68
If you trust your shop get them to sonic test the block to see how much material you have. I have a 393 bored .60 over after a good result from sonic testing and it is fine. I have seen many comments from reputable posters that .60 over is no good and will always overheat. I believe there are many other more significant reasons your bronco will overheat.
braxton357
morganton NC
It's pretty widely known that a .60 and over windsor block is pretty much trash. Especially when they can be had for so cheap.
tabascom16
Salisbury, PA
After I pulled the 351 that was in my Bronco out I found it was bored 60 over. I had no overheating problems even with the stock radiator, but I did have quite a few cracked rings. I don't know if I can point the finger at the .60 bore.
fordguy
you can take it to the machine shop and they can mic it and tell you if the cylinders are within tolerance if you think .40 will not clean it up it is most likely not within tolerance for re-ring but check to make sure before you jump in
74bronc
I wouldn't do it if it were mine. last time I had a resleeving done, it cost 80 bucks a cylinder. Maybe they discount for the whole block but it seems to me you could get a decent STD block for ALOT less money, unless they are REALLY hard to find in your area
moabbronco
Payson, Utah
I am running a 351w with an .060 overbore and have had no heat related problems. After I cleaned out my radiator, 3 inches of junk in the bottom from the PO. It may get a little warm from time to time but It never boils out any more.
bronco-billy-66
bronco-billy-66
Madison Mississippi
UPDATE....It turns out mine is '72, i was told from my local Ford Super Guru Is a beefy block. He says that the pre '74 blocks are 10 pounds heavier and have a higher nickle content....he says .060 over is not a problem as long as my cooling system is in good working order...Which is true for any build up %) decisions....decisions...I wish I wasn't so Cheep
76Broncofromhell
Bronco Totalitarian
Grass Valley, CA
Check the cylinder taper before you do anything. If it is less than .005 then you can bore it .040 over and be fine. If it is over that I would say look for a new block. You would really only feasibly sleeve a block if you had something as rare as a 4 bolt main 351C or a Boss 302.
