Boring videos.
Scrapper_MV
For you viewing pleasure.
My friend Joe's corn binder (IH Scout) gets pulled out by my Bronco proving once and for all which is the superior vehicle.
http://www.youtube.com/watch?v=NOAQMtNzYa8
My Bronco climbing a small steep hill with no throttle. It just idles right up. I love my gears!
http://www.youtube.com/watch?v=xjrHRWPNoz8
After these videos were shot I proceeded into the rocks where I bent my steering linkage all to hell. :mad:
sprdv1
REBEL
I assume the scout don't run since he wasn't assisting in the recovery, LOL
S
Scrapper_MV
It runs good, but he has open diffs. So he got stuck spinning two wheels in the loose cobble stone. I told him I could pull him out easily, so he tried to make it hard by not helping. He even wanted to video it because he thought I wouldn't be able to pull it out. HAHA!:p ;D
BuffDragon
CenTex
very nice!
for those of us that dont know (I'm a newbie!) can you put up a few specs on the pony?
bigmuddy
Marthasville Missouri
Scrapper, nice looking rig. Your buddys scout looks good too, I have always had a fondness for the old scouts. What kind of gearing are you running?
Ben
S
Scrapper_MV
My Bronco has a 351W (carbed) a NP435 trans with 6.68:1 first gear, the Dana20 was re-geard with 4.86:1 low gears, the front is Dana 44 with 4.56:1 gears and a detroit locker, rear is a Dana60 with the same. Tires are 35". So what does that make my final crawl ratio? It's low, and I like it! In first gear, 4W low I cant hold it back with the brakes!
S
Scrapper_MV
Ben
The Scout is actually a great rig with an AMC 360 that makes lots of low end torque. He has about 6" of suspension lift and the front axle was pushed forward about 3 or 4 inches. The rigs down fall is the 3.50:1 gears and open diffs. If he had gears and lockers he could go anywhere I do. But for now I'm happy to pull him out and give him sh!t about it.;D
sprdv1
REBEL
LMAO, if only he knew the power of the "Bronco" Nice man :cool:
broncotime
Grapevine, Texas
My Bronco has a 351W (carbed) a NP435 trans with 6:1 first gear, the Dana20 was re-geard with 4.56:1 low gears, the front is Dana 44 with 4.56:1 gears and a detroit locker, rear is a Dana60 with the same. Tires are 35". So what does that make my final crawl ratio? It's low, and I like it! In first gear, 4W low I cant hold it back with the brakes!
How did you regear your dana 20? I've seen the Teralow kit that will take it to 3.15, but I'd like to hear if there are other options out there. I don't want to drop the coin that an Atlas or Stak would run right now.
S
Scrapper_MV
The t-case was re-geared several years ago by the P.O. He used a kit called "JP Rock Eater". The company that made them is no longer in business.
trailpsycho
Those are the Jack Obrien gears. Yes, he is still in business. Try a search using "Obrien gears" You should get several hits, including this one.
http://classicbroncos.com/forums/showthread.php?t=120963&highlight=Obrien+gears
These gears are very expensive, however. BCB used to sell them. Last I heard they were in the $1200-1500 range--for just the gears. Thats Stak or Atlas territory. The Tera Lows are fine...seem to be doing well in my rig...
Of course, Scrapper's 146:1 1st gear in low is impressive...but unless you exclusively crawl, there is a very wide gap between high range and low range.
Whereas the TL gears net you a 30% gain in low range gearing...significant...especially if you can score the gears on sale. Also, its advisable to update the rear output shaft with either of these gear upgrades, which raises the cost by an additional ~$375-400 on top of the gears and rebuild kit.
broncotime
Grapevine, Texas
Thanks. I've got a doubler in my yellow truck that gets it down to 150 to 1 and I love it (also did the WH heavy duty output shaft at the same time). I was looking for a cheap easy way to get some lower gears in the newest trail truck I am trying to get together. Once I get the NP435 installed, I will be at 85 to 1 craw ratio, so I may just quit there and call it good and put my $$ towads 4 linking the rear suspension.
S
Scrapper_MV
Of course, Scrapper's 146:1 1st gear in low is impressive...but unless you exclusively crawl, there is a very wide gap between high range and low range.kit.
Did I mention that I also have an Advanced Adapters overdrive unit? With only 16 forward gears to select from it's not a problem finding one that works. :)
Skiddy
that many gears i am pretty sure i would have a problem%)
Bundy
Hey Mike, is your buddies IH an 800 series? my brother used to have a killer 800A... he took it to a guy out by palmdale to have him build it into a decent crawler and the guy stopped returning his calls... anyway i would love to send my bro the info if Joe knows a good IH locally.
i am hoping my bronco inspires him to go get it back!
S
Scrapper_MV
Yeah it's a 71'. The last year of the 800 I think. He knows a great guy here in so cal that works on his rig. PM me I'll get the number for you.
