Bottom radiator hose question
itsabronco
Banning, CA.
Does anyone know of a bottom radiator hose that fits from the stock location on a 302 to a reverse flow radiator ? You know like you can get a 7.3 diesel to basically fit from the Ford Explorer 5.0 EFI set up to the stock bottom location on a radiator. Just opposite of that is what I’m looking for.
Thanks in advance if anyone comes up with something. If i find something out, i will certainly pass on the info
rustbucket
I use the flexible stainless steel hose. I can’t remember the brand, but it was the first one to come out. Summit has their version too.
Sent from my iPhone using Tapatalk Pro
pcf_mark
I used a piece of exhaust tubing it looks like a J I made. Any muffler shop can probably bend you one. Then I fitted a piece of a stock radiator hose on each end to make the connection to the water pump and radiator.
toddz69
I believe Wild Horses sells a crossover tube for that .
The crossover is for the opposite scenario - driver's side water pump intake and pass side radiator exit.
Todd Z.
Jdgephar
I can send the hose numbers that I used for an Explorer radiator conversion and the stock belt drive water pump.
I dont get back home until Tuesday though.
Sent from my SM-G950U using Tapatalk
