Brake fluid in PS Pump
strider
Holland
Ok, I finally had my brakes working very well but I had a little bit of whining coming from the PS pump. This pump is supplying the hydroboost unit and the steering box. I had my neighbor look into the reservior while the engine was running to see if it was foamy, which it wasn't. I told him to just splash a little more ATF in the thing just for good measure.
Bad thing is that the bottle of ATF he grabbed was used last night to bleed brake fluid into. I learned that the pump does not like brake fluid at all.
Any suggestions? I'm able to easily drain this system, but how much damage, if any, could be caused to the seals in the hydro boost unit after 45 seconds or running with probably a quarter cup of this nasty liquid? How about the pump? I was contemplating the switch to a saggy pump anyway, maybe this was my sign that it needs to be done.
eds66bronco
Essex, Vermont
get it out asap and flush with new atf or power steering fluid. it will swell seals if left in for too long. keep it running and disconnect the return/s and dump into a bucket as you fill the res with new fluid. make sure to pump the brakes and turn the wheel lock to lock several times to purg the box and the accumulator on the booster. i did the exact same thing after i rebuilt my pump. i grabbed a bottle of what i thought was synpower fluid and it turned out to be the bottle i had used the day before to bleed my brakes into. now i keep a sharpie marker and label my bottles and peel the labels. sux doesn't it?
Yep, drain and flush ASAP!
Brake fluid is a seal sweller. If you had a weaping seal it probably stopped by now. Go much longer and it will fail. Hopefully the amount of brake fluid is fairly low and it's actions hopefully are not too severe.
There is always the snowball's chance that everything will be OK. I have seen it once. Friend didn't know what he was doing and put power steering fluid in the brake system. The rubber in the 2 systems is not the same. The brakes should have died. But somehow the leak he had stopped and he drove it a couple of years that way. I could go on for a long time about all the stuff he got away with that he should have died several time over. Still don't know how he outran the cops in a Mercury lynx that he puller the lifters out of 1 cylinder because it was burning too much oil?
