mpboxer
Previously, I had power drum all around which stopped good. All new brake lines about two years ago. Upgraded to Duff’s Monster Disc and kept my rear drums.
I’m at a loss. I have good brake pedal when the engine is off. When I start the engine the brake pedal drops about 3” and I have very little travel remaining and the pedal is soft. I was able to drive it and the drums don’t lock up and it stops straight. Definitely not safe or correct though. Too much play in the pedal and way too soft.
Something I noticed also. When bleeding the rear brakes after the brake pedal gets pumped up and the bleeder screw cracks open the pedal drops dramatically (which is good). It doesn’t do that when bleeding the front calipers. The pedal only drops a little bit. Is this normal?
Things I have done:
Brake pedal height before 6 1/4” after 6 3/4
Adjusted shoes
Bench bled MC x3
Adjusted rod to MC x2
Verified bleeders on top of calipers
16 inches of vacuum (which worked fine with previous Toms booster)
Bled brakes for hours (manual and vacuum)
Confirmed brake lines installed correctly to proportioning valve via instructions
Verified no warning light for proportioning valve (therefore I think the piston is centered and I use the plug when bleeding)
Thank you for any insight!
Mike
Things I have done:
Adjusted shoes
Bench bled MC x3
Mike
