KBUCK1
- Feb 8, 2011
- 979
I have a disk brake dana 44 and 11 inch rear drums. Manual master cylinder from 84 ramcharger. All new brake lines including braded stainless lines from frame to axles. I have bled brakes numerous times and Im confident the air is gone. Also, a good friend that used to work in a shop come by and confirmed that they were bled as well.
I have a very soft pedal. I have narrowed the problem down to being in the front. I disconnected the front line from the master cylinder and capped that master cylinder port off and the pedal is rock solid. ( the rears are working great) when I disconnect the rear line from the master cylinder and cap that port the pedal is very soft and nearly goes to the floor. I have confirmed that the calipers are not on backwards and both are new calipers. Also, Im using an H block and not a proportioning valve. Does anyone have a clue what could be going on?
