- Nov 3, 2003
- 51,656
...could they have given me a caliper thats wrong that would bolt up but cause problems?
I'm not absolutely sure, but I don't think so. The only calipers I've seen that Ford made that bolt up to those brackets and still have the normal hose fitting are the ones for trucks. And those should all be the same.
By "wrong" the only thing I can think of that would cause something like this is a mis-matched mating/sliding surface.
If you had one with a larger piston, you'd still have a firm pedal because your 1.125" bore master should be able to push enough fluid.
By any chance are you plumbing the front reservoir to the front brakes? Or are you using the rear reservoir like original? As mentioned, some masters might have different piston flow capabilities (don't know this for sure either, but have heard of it elsewhere).
If the sliding surface is wrong, damaged, rusty, or the slider/anchors are wrong (or installed incorrectly), you could conceivably have an issue like this.
When you put all the new stuff in, did you get new hardware for the fronts too? There are different versions of the caliper anchor with it's spring that would jam up and not allow the caliper to slide on it's mounts.
How hard were the calipers to install? Did you have to really hammer the anchors in, or did they go int smooth and easy?
