brake lamp switch woes....
tasker
all knowing of nothing
NH
recent rebuild of entire truck as documented on Mig's Bronco barn page. My problem is with the stomp lamp switch. It does turn them on, but you really have to Sasquatch stomp on it. The pushrod seems like it has too much throw before engaging the switch and with Hydro boost brakes I have no need to stomp that hard. I'm thinking either a shim or perhaps a different pushrod? Thoughts? i tried a piece of stainless but think it's too rigid and keeps the lights on constant. Pics for an idea of what I am working on, (SAME PUSHROD as pictured, had new from a box of parts
Yeller
Rogers County Oklahoma
I got tired of changing them, was having annual failures, so I went to a GM switch on a simple bracket clamped to the steering column with a hose clamp. I'm away, otherwise I'd include a pic. I know hard for the Ford Parts Man to do LOL. but I haven't had a failure in a few years now.
tasker
tasker
NH
thanks buddy...seems so easy in theory but I really don't want to get hit!
Not to worry, it’s not a GM-exclusive part.
Most of the manufacturers, including FORD, use plunger switches now and in the past. My 79 Pickup uses that style.
You can even buy them in both varieties, whether it’s push-on, or push-off.
Gives you more options for mounting your bracket in different orientations.
I’ve done several vehicles that way. And only one of them a Ford.
In fact, this two styles thing often cause trouble at the purchasing end. Wouldn’t hurt to take an ohm meter with you when you buy one at the parts store. Or if you buy online, check it before you waste time installing it.
They often come mis-boxed, and you end up with opposite of what you intended.
tasker
tasker
NH
YEP...tried a few different switches too, same deal
Kalex
Novato, CA
I was having all of the exact same issues as you. Tried to remedy it exactly as you also. About 4 years ago I went to a plunger style switch and has worked flawlessly ever since. My biggest concern is how flimsy/cheap the switch feels, but it works. I juts made a little metal "L" bracket for it to attach. I can take pics if you need it, nothing fancy for sure. I don't remember what car the switch is from, but just told the local Napa guy and no problem.
ksagis
Aspiring Bronco Guru
Austin
There's also the bushing that goes between the brake pedal and rod that is hard to see in EPB72's pic, you have it too?
I added the bushing and the lights were on all the time, added a new switch and all good. The action of the pedal and switch is super confusing.
If you add the bushing and remove the strip of metal, maybe will give you the sensitivity you're looking for. You might also check that you haven't over-extended the pedal adjustment rod (if you have that) to be sure you have enough movement to trigger the switch.
Edit: there might be some nuggets in this thread I started earlier today.
Master Chief
Randy,
ksagis nailed it. I had the bushing on mine. Installed the new hydroboost and the lights stayed on. Removed the bushing and they function normally. I would try the bushing with yours first. That may be all you need.
Roger
ntsqd
heratic car camper
Upper SoKA
Even with the bushing it's a Stupid Ford trick that the brake light switch does that. Had local PD light me up in the Ranchero a couple of decades ago. I knew that I hadn't done anything wrong in the time that he was behind me, so when he told me why he stopped I repeated the Sasquatch Stomp and the lights worked. He came back all apologetic. I told him he wasn't not seeing things, it was a Stupid Ford Trick and that I'd get it fixed.
How I executed Yeller's suggestion in the Wagon, because that vintage Wagoneer has the even dumber hydraulic pressure switch that fails and costs you the brakes:
tasker
tasker
NH
FOUND one, new switch in already. Hopefully this fixes it. Thanks and will update
toddz69
Randy,
Roger
I had the exact same problem. Tried the bushing again a few years ago - thought maybe I was smarter than I was years ago. Nope. So bushing came back out.
Todd Z.
ntsqd
heratic car camper
Upper SoKA
The push-rod needs to have some movement on the pin in order for it to move far enough to actuate the switch. It's a clever design, but I've not cared for it since that day with the Officer.
tasker
tasker
NH
Todd Z.
END up going a different route then?
