Bucky
I searched the old Brake Light Trends and could not find an answer to my problem. I have Disc/Drum Brakes and I'm not sure how to make the light go out. My question is with the ignition switch in the On position, and the connector disconnected from the proportioning valve should the light go out? I can not seem to crack the code on this one! I have a Painless Harness and the only way to get the light to go out with everything connected is to disconect the supply voltage from the ignition switch!
Thanks for anyone's help!!!
