If the turn signals work then the second filament in the buld should be fine. Check the connections on the brake switch. It's at the top of your brake pedal where the brake pushrod connects. If both wires are connected to the switch then test the wiring by carefully (don't want to short them to other metal parts or dash or body pannels) unplugging both wires and touching them together. If the brake lights come on then, then it is your switch. If they still don't come on then you have a wiring problem somewhere between getting power to the switch or between the brake switch and the turn signal switch probably.
