brake problems....ARGH
Clint
Grand Junction, CO
So, I everything new in the brake system. New calipers, lines, hard and soft, and new 1 1/16 bore disc disc MC. (chebby 1/2 disc front, monte carlo disc rear). The rears lock up but the fronts WILL NOT. Ive got it jacked up in front wheel drive and the fronts will turn right through the brakes. This indicates to me that I got a faulty MC, correct? There is plenty of adjustment in the calipers, meaning that Im not bottoming them out before they clamp the rotors... System has been throughly blead.
So, any way to test this or just go get another one and see how it works?
t.lay
Grayslake, IL
A couple of things to check - do you have a proportioning valve? Also, if you have compartmentalized reservoirs - is the big reservoir connected to the front brakes? Seems like you've got good line pressure to lock up the rears, but not enough pressure for the fronts, or not enough pressure at the fronts in comparison to the rears. How's your pedal pressure? Quick check for your MC - put even pressure on the pedal - travel should stop before the pedal bottoms out. If the pedal stops - then starts sinking - maybe worn seals in the MC - otherwise, I'm thinking it's a proportioning issue - this comes up more with an all disc set up.
C
Clint
Grand Junction, CO
Update: I had thought the rears were locking up but they are actually worse than the fronts. With it in 4high I can lock fronts/rears up easily, but in 4lo its pretty much not happening. I can jam be pedal and get the bronco to stop but its the fronts doing it. In rear wheel low, the rears wont stop at all, they slow down and will pause but keep spinning. So, I have crappy brakes in the front and almost none in the rear. The prop valve on the rear is a new wilwood prop valve and is opened up all the way. I have messed with it to see if anything changed but nada. The big reservior is connected to the fronts.
Like I said, the MC is new, but new does not mean good these days it seems. The pedal does not sink, but I have to jam it pretty hard to get it to stop in either front or 4lo, and it will NOT stop in 2 rear low.
fishnxlt
Sierra City
i cannot lock my front disk up either unless i absolutley stand on the pedal! Truthfully, i like it that way as a locked up front does you no good. I do not have power brakes
C
Clint
Grand Junction, CO
Ive got to be able to stop. If I can BARELY stop it when its on jack stands in the garage, how will it stop when rolling down the road, or on a steep climb when wheeling? Answer: it wont.
t.lay
Grayslake, IL
had another thought - are you using the stock push rod - from the pedal to the MC? running out of travel before you're running out of MC? Also - are you trying to stop a lot of rotating mass (big wheels and tires)? I'm running 36s and steel wheels - went with a hydroboost set up - low effort and stands it on its nose. Had some issues with the stock push rod - went with the original and made a difference - although I had to mess around to get the brake light switch to work. Seems like you've got pressure - the bore size should be ok. Got any kind of power boost - or are you running manual brakes?
C
Clint
Grand Junction, CO
Well as it sits right now, wheels are off, its on jack stands. Completely manual brakes. I have a SuperDuty Hydroboost sitting in the shop. Guess its time to go down that road. Dont think im running out of travel as the MC bottoms out before the pedal hits the floor (did before I bled it out)
t.lay
Grayslake, IL
It only took me one drive with 4 drums to decide on the most power I could muster for brakes - although hydroboost comes with it's own set of issues (fittings mostly - converting metric to sae...had a high pressure pipe break - what a mess).
fordtrucks4ever
DFW
You also need to run the pads in a little before they start working well. Dont think this is the issue you have, but should make some difference. I just replaced pads on my 4-wheeler. Talking about something that didnt stop for the first few hours of hard riding...
ken75ranger
Troy, NY
The rear brakes in my '75 were just like your describiing even after putting in the hydroboost. I put in 76-77 Bronco wheel cylinders and it did the trick. The 76-77 wheel cylinders are a little bigger bore.
broncnaz
I second this.
Also if you put in the high $$ pads they tend not to work well at slow speed until things get heated up.
When I did my disc conversion it didnt stop as well as I hoped it would at first after a while the brakes came around. I know a lot of people that will say go H boost but your really only covering a problem not a good idea when its your brakes. You may need the 1 1/8" MC.
