Brake light/flasher problems
jwats73bronco
While installing TBP led upgrade kit, I discover no brake lights and no rear flashers? Front flashers work. Turn signals and parking lights work at both ends.
Fuse in glove box is good. Brake light switch is working? Truck has newer
Centec harness. I also cleaned all rear metal grounds as truck has been repainted.
Stumped? What next. Long jumper wire or start looking for wiring harness problem?
How are the brake lights and rear flashers related?
Thx
gr8scott
Was this a LED headlight conversion, or LED lights all around? Post a link to the kit you bought.
J
jwats73bronco
Truck came with halo (I assume) led headlights. I decided to add led kit from TBP all around. My wife reported a problem while following Bronco with driver’s brake light. Not working on soft pedal. Working on hard pedal? Passenger side seemed fine.
So I moved forward with led upgrade. Found some strange splices in rear wires to tail light tubs like crazy trailer brake hookup. So redid those with shrink wrap connectors. Now have tested last plug connection before tubs. No power?
So after no brake lights with led boards went back to 1157 bulbs. Still nothing and no rear flashers?
As reported. Fuse is good and I have test light power on both sides of brake light switch. Output side brake light switch functions properly with brake pedal?
Have rear turn signals and rear parking and headlights? Front flashers seem fast but working?
J
jwats73bronco
I just checked TBP. There is a newer version of my Led upgrade kite now. All my front turn signals, parking lights and side indicator lights as well as backup lights are plug and play.
Rear turn signals, brake lights and flashers? Are led boards. I did install the load equilizers. But they are out of loop for now as I just tried to go back to stock.
I have tried new standard flasher and led flasher with polarity reversal.
Both work in front. No flasher in rear?
J
jwats73bronco
A little more info this morning. After reading several links were turn signal switch was involved, I tried depress the break pedal and jiggle the turn signal lever.
I depressed the pedal HARD with a locking brake light depressor. Turned on the driver’s side blinker and when I turned it off I had a working break light. Couldn’t make the trick work on the passenger side?
So for now I have functioning side indicators and parking lights, functioning headlights, functioning turn signals, front flashers and one brake light under conditions outlined above.
I am going to reverse the leads on brake light switch and see what happens. I have a new switch ordered.
My next guess is turn signal switch as I seem to have continuity of all wires to rear tubs? And all the links say everything has turn signal switch in common going back?
Slowleak
Georgia
That’s my guess as well. My brake lights would not work unless in grabbed the turn signal lever, right where it meets the column, and pressed it towards the firewall. It got to be a habit every time I stepped on the brakes. I eventually rigged it up with some rubber bands and got by until I could replace the switch.
J
jwats73bronco
Thx for all the input. I went back and pulled out my crimp and heat shrink connections to repair previous cuts in wire insulation. Repaired driver side with solder and shrink wrap. Like magic brake light and flasher work. Did the same on passenger side. Flasher worked at rear.
Called wife down to check brake light function. NOTHING! On either side? I admit my solder job is poor.
So I ordered two new tail light buckets from Tom’s. We will see come Friday and then continue with LED rear board install. Hoping to avoid pulling steering wheel and replacing turn signal switch and harness.
