My brake warning like has never activated when the ignition key is turned. I understand that it should be on temporarily either when the key is first switched on, or maybe when turned to start. I have tested it by grounding the wire at the proportioning valve and the light does work, just not when i turn the key.
Anybody know what triggers it to activate when the key is turned? Should it ground in the switch when the key is moved to start?
