Yeah, it's the same style we sell as a standard proportioning valve. I think everybody sells them nowadays, and probably from the same three or four companies.
I've had defective ones before, including one that made the front brakes drag.
Maybe they'll replace it for you if you are diligent in your testing to make sure it could only be the prop valve?
Still sounds like at least part of the issue is something else though.
One thing about part of your issue, is your left/right problem with only one tire locking up. This type of issue at the rear can't be caused by anything forward of the hard lines on the axle housing. Nothing up front, from the soft hose to the frame, all the way up to the master cylinder can cause one side to brake harder than the other. That can only be done by some malfunctioning part, or inconsistent assembly or adjustment.
My point is that everything in front of the hose to the axle would effect both brakes equally. So the fact that only one wheel is locking up (as opposed to both) means the problem is only at the back axle.
Now, that's just the side-to-side issue. The problem with the rear having more power than the front is another matter.
For a proportioning valve, I like using an adjustable one in the rear system only. One like these:
https://www.wildhorses4x4.com/category/Bronco-Proportioning-Valve effects only the rear.
But both equally, so you still have to deal with the one side braking harder than the other.
Do you still have the original H-block that was mounted to the frame? If so you can reinstall it, plumb the lines back to it, and then test the brakes. There is no restriction with an H-block to cause trouble. It's just a distribution block and the ports pass straight through.
They are still worth checking out before installing however. Water can get in and cause corrosion, as well as other things happening to them probably. Make sure it's perfectly good before installing.
Depending on the size of the fittings down at the current proportioning valve, there may be a simple threaded coupling that can mate the two halves together to bypass the prop valve. I just don't know the thread sizes or if there is such a thing as the coupler without you having to make one yourself.
Maybe someone has done this before. But the H-block would be the easiest to make work I would think. So if you have one, start there.
I suppose if you're not against spending a little more money (when does it stop?) you could have a hose made that runs from the master all the way down to the frame without stopping for any other components.
S
Maybe some others will come up with a simple solution. Probably someone's done it.
