I can't think of the part number for the bulbs now but if you replace the old round bulbs with the elongated bulbs it makes a big difference. I will get the number and post it when I get home from work.
Would it be from #57 to 1895 bulbs?
I used wagner 1816 bulbs they are 13 volt. The bright gauges are the 1816 bulbs and the others are the stock bulbs.
hdfx---where did you pick up those bulbs?? I also have very dim dash lights---even after a good wipe down/clean out of the gauge cluster. Need to pick up some of those wagner1816s....thanx.
