- Joined
- Nov 11, 2007
- Messages
- 8,778
Not uncommon but rare. That could be a result of not getting the Tq converter all the way on, the insert, clunk, turn a bit push it on further. Problem is, it also could mean inside tranny, the pump housing is probably broken. You'll need a new torque converter and tranny opened for inspection. Good news, everything is repairable.
When install, did or were you able to push tranny onto engine block, or did you need to use the bolts to tighten it together?
