I think it is funny how people talk down Bronco IIs so much, but you never hear the same negativity about 1st and 2nd gen Rangers which were basically the exact same thing %) It is amazing to me how the Consumer Reports rollover PR has tainted public opinion to this day.
They are decent little trucks for what they are and go for dirt cheap. If you don't care about the styling or size of the Bronco II though, you are better off getting an Explorer since they have all the upgraded drivetrain components the Bronco II never got and go for dirt cheap as well.
The '84-'85 had the carbureted 2.8L Cologne V6, which is pretty gutless, but quite durable. The '86-'90 models got the EFI 2.9L Cologne V6 which is a decent power upgrade in addition to getting fuel injection (basically identical to the 5.0L EFI system of the same era). The main issue with the 2.9L is the cracking heads, but at this point I would imagine that issue has been fixed on any of them that are still on the road.
The A4LD automatics in most of them are notorious for crapping out, but the '84s have the C5 (basically a C4 with a lock up converter) which is desireable for V8 swaps and durable. The '84s also had the 4 speed Toyo Kogyo, which is a decent tranny, but a 5 speed was optional that year and all other years had only a 5 speed available. All the manual transmissions are decent, but the Toyo Kogyo 4 & 5 speeds are typically considered the best and have the lowest first gear. It is a bit of a crap shoot which manual you get.
All 4x4 Bronco IIs have Borg Warner 1350 transfercases which are reasonably stout and reliable (there are rumors of some '90 models getting the 1354 which is slightly stronger, but I am not convinced any were actually so equipped). Some of the later Bronco IIs ('87+) got a version of the BW1350 with a solid front yoke (most have a slip front yoke which isn't really an issue even with lifts). Just stay away from the electric shift models because the shift motors are notoriously problematic and can leave you without 4x4 when you need it most.
The 2 wheel drive Bronco IIs got the dummy Borg Warner 1359 tranfercase. Thus all Bronco IIs use 4x4 transmissions unlike the Rangers and are one of the easiest vehicles to convert to 4x4.
All Bronco IIs had a Dana 28 TTB front and a Ford 7.5" rear (again there were rumors of some of the '90 models getting the Dana 35 TTB, but I don't put much stock in them). These axles don't have any real issues, but are pretty weak. They won't hold up to heavy offroad usage with anything much bigger than a 31" tire. The good news is that the Dana 35 TTB out of an Explorer or Ranger is literally bolt in and will hold up pretty well to 33-35" tires in stock form (although the auto hubs are weak). The Ranger 8.8" will bolt in as well, but you would be better off getting an 8.8" out of an Explorer since they all have 31 spline shafts and are a little wider than the Ranger axles.
Personally I would shop for an '86-'88 since I prefer the 1st gen interior and exterior styling over the '89-'90 2nd gen, and I would prefer the fuel injection and power of the 2.9L over the earlier 2.8L. I would also look for a 5 speed manual with a manual shift tranfercase, preferably a Toyo Kogyo with the solid front yoke BW1350. However, those wouldn't be sticking points, just avoid the A4LD and the elctric shift transfercase. The only real reason to consider the 2nd gen '89-'90 is that a 4.0L OHV out of a Ranger or Explorer is basically a bolt-in, plug and play swap. The 4.0L is bolt in for the other years as well, but the wiring is a bit more of a hassle.
The prices for Bronco IIs are pretty consistent regardless of year or specific drivetrain configurations (save for the 2WD versions). A clean 4x4 should go for $2,000-$3,000. A 2WD in the same condition would go for $500-$1,000 less. A clean 4x4 with the desireable parts swapped in (4.0L, Dana 35, Ford 8.8") and a lift and tires would go for $3,000-$5,000. A good-running 5 speed model with near stock-size tires should be able to pull fuel economy in the upper teens to low 20s depending on your driving conditions and style.
