First question is,
-did you have the lean before you replaced the bushings, or the axle or the springs, or whatever you've just done?
I'm asking this because if the lean was there before it could be from a body mount, weak coil springs, weak leaf springs, bent frame, half a dozen other variables...
However, if it was level before, then, yes, the bushings can slip.
Did you coat them with bushing grease?
I enjoy trying to figure this out for several reason but also because I was the guy that accidentally figured this out back in about 97 or something when I put my first extended travel, soft spring suspension in. I wrote the original article that was in BroncoFix back at the start of Bronco forums and EBML as we were all trying to figure this out, back in the day!
I only mentioned all this because there are so many variables and after I posted this up 27 yrs back
it's pretty much been the steadfast rule that if you didn't have the lean before & you have it after just replacing the springs up front or the bushings up front, then that just about guarantees that it's the alignment of the ends of the radius arms, not being parallel.
Keep trying...
